0 Members and 1 Guest are viewing this topic. Read 16411 times.
It seems likely that single source systems will have a much higher percentage spent on speakers.
Or not. In it's current configuration, my speakers account for about 20% of total system value in a single-source system. When my new speakers arrive, that's going to bump it up to about 33%. I see a lot of different paths taken here and it's all good.D.D.
Interesting we now have three posts of owners of magnepan speakers where the speaker cost is a very low percentage of the total cost.I think this says a LOT about Magnepan speakers being a huge 'bang for the buck' item.. and how the Magnepans can benefit so much more than average from really good electronics.(sorry if this sort of derails the thread a bit, I am glad though, that I am not the only magnepan owner with this sort of percentage)
I don't know, that's a lot higher than 10% (one of the outliers posted above)
Sorry, but "Dollar Percentage," is a meaningless term associating non-defined values that describe nothing. A dollar is a dollar, 20% is twenty cents. "Value or Budget Percentage," would be more relevant.
If you dont believe that cables, or even different amplificationmake a difference, then your speaker cost would represent more ofyour system cost. If you are a cable and amp believer..... those$3500 cables and brand 'X' amp are bringing your percentage way down, or thatlamp cord and AVR is bringing it way up.And where does DIY come to play when comparing?
I was going more by what it is worth now vs. what I paid for it. When I adjust for the value of the system as is instead of price paid, I come closer to the %40 figure. My speakers have the highest resale value of any component in my system... and that's as it should be IMO.
Yeah, change the fomula to fit what the op wants to hear. No problem.Then I too have 50% speaker 50% amp.Happy?Then another 50% preamp. the a second preamp I use as a fancy tube buffer list $4,000 includes another $1K in mods.. So that is 50% too.Another preamp I use for it's great phono section, that was list $6,000 so another 50%Then $5,000 worth of turntable so another 50%$5K for the digital stuff another simple 50%Then $5,000 worth of power conditioners and yet another 50%So I am glad i am in agreement: 50% for speakers LOL
