You lost me at the schematic! Why all these electrolytic capacitors across the signal input terminals?
Randomly adding electrolytic capacitors to a component is seldom a good idea and sometimes blows up the rectifier diode bridge.A jr. member of our forum 'gootee' added a lot of information to a long thread in another forum:http://www.audiocircle.com/index.php?topic=117488.msg1238397#msg1238397long thread:http://www.diyaudio.com/forums/power-supplies/240955-resevoir-capacitors-chip-amps.htmlWhile replacing old electrolytic capacitors with new units that have a higher voltage or temperature rating and a larger value (but with a similar footprint) can be a good idea. Just adding lots of caps is a bad idea.
Good point. Salis should spend another minute and a half on the schematic to indicate that the caps are placed across the DC power input terminals, not the signal input terminals. Good idea though. A next step might be to add a choke for a CLC filter. The Felix thread will have some notes on this.Russ
