0 Members and 1 Guest are viewing this topic. Read 10702 times.
I'd look into the damping factor on both amps, and what that Hawthorne driver needs for damping. Higher damping power (to a point) will give you tighter bass, though it is possible to overdamp some drivers. I had an Aleph 3 that I liked with my 12" Audio Nirvana drivers, with the exception of the bass, which was overdamped with that amp.
Maybe this will help.http://en.wikipedia.org/wiki/Damping_factor
What dictates the damping factor of an amplifier or driver?
The equation on the Wikipedia page is DF= Zload/Zsource, where DF is damping factor, Zload is the nominal impedance of the speaker, and Zsource is the output impedance of amp. From the schematics of the amp, and from what I got from scanning the interweb, the output impedance of a tube amp is determined by the output transformer. Using OPT's with an 8ohm tap, I'd get a damping factor of .75 with my 6ohm nominal speakers. Using a 4ohm tap would bring the damping factor to 1.5. Am I figuring that out correctly?
I don't think so Strider because, to simplify, the damping factor figure should be higher with 8 ohm than 4 ohm. Damping factor is defined as the nominal output Z of the speaker divided by the output Z of the amplifier. (Your equation is correct.)For instance if the output Z of the amplifier is 2 ohms, damping factor with 4 ohm nominal speaker is 2, 4 divided by 2.With 8 ohm, the damping factor is 4, 8 divided by 2.Hope this helps.
Won't be able to tell unless you give us the specs of your gear and let us k ow what values you entered. Sorry, not going to look that up myself.
Have you considered a SE KT120?, should be able to push 20-25 watts.I just took delivery of a SE kt88 amp yesterday and even without much break in I'm liking it a lot.
Seemed too simple I am in the formative stages of the learning process, I do appreciate the help.
