Adding a selector switch to my TLP.
0 Members and 1 Guest are viewing this topic. Read 1273 times.
Martin
« on: 2 Aug 2004, 01:15 am »
Hi All
 I'm getting ready to add a selector switch to my TLP.
It's a 6 pole (12 solder tabs) with pins for stops. I intend to have 3 positions.
There is not much in the way of instructions for wiring.
Does the "hot" from each pair of RCA's attach oppisite each other on the switch? If they do, do I terminate all the "neutral" wires
to a central pin or post?
 Please, any info would be helpful. I'm sure this is really pretty easy, but to a novice like me got me scratching the cranium.
Martin
stvnharr
« Reply #1 on: 2 Aug 2004, 02:32 am »
Martin,
The Right and Left go to the selector switch.    Make sure you get the "Rights" all together, thus making the "Lefts" on the opposite pole.
Grounds all go to ground.
You'll find it to be quite simple.
Lost81
« Reply #2 on: 2 Aug 2004, 03:20 am »
Hey Martin,
Have you upgraded your TLP to Nirvana status yet?
I totally recommend it.
There is an appreciable difference.
Right now, I've got all the parts to bring it beyond Nirvana, but I don't know if I should install them now.
The TLP Nirvana has been in storage for a year, and my new AKSA 100 Nirvanas need their 20 hour break in (Hour 1 slated to begin sometime tonight :beer: :drums: ). Besides, BlackGate capacitors are supposed to take forever to come up to speed, especially with regards to bass (from what I heard).
-Lost81
Martin
« Reply #3 on: 4 Aug 2004, 11:28 pm »
Thanks stvnharr, thats kind of what I thought, nice to get a second opinion though.
Yes lost81, I ordered my TLP with the nirvana upgrade, same with my 100w
Aksa amp.
Thanks Peter for helping with the sourcing...good company...no hastles.
Martin
