High quality desk top speaker? Full range drivers...
0 Members and 1 Guest are viewing this topic. Read 136723 times.
BK_856er
Re: High quality desk top speaker? Full range drivers...
« Reply #400 on: 9 Feb 2014, 10:14 am »
Coming together nicely...
jcotner
« Reply #401 on: 27 Feb 2014, 06:43 am »
Hey Danny are the drivers on the boat yet?
It's been a few days since anybody has posted to this thread.
Danny Richie
« Reply #402 on: 27 Feb 2014, 04:13 pm »
Yep, they are on the water.
devinkato
« Reply #403 on: 28 Feb 2014, 07:17 pm »
Getting antsy, gonna get my scuba gear on and go hijack that boat if it doesn't get here soon!
Danny Richie
« Reply #404 on: 4 Mar 2014, 10:15 pm »
They are due to arrive in port on the 7th.  :D
IronForge
« Reply #405 on: 5 Mar 2014, 04:08 am »
nice! Hopefully they make it off the boat safe and 'sound'.
JakeJ
« Reply #406 on: 10 Mar 2014, 08:09 pm »
Danny,
I just went through the thread looking for some more details on cabinet assembly.  Did you ever post the cutback depth on the No-Rez for the driver?  And how did you cut that groove in lower section for the port, is there going to be a port tube included with the kit?  I am planning on assembling my cabinets in the next couple of days so any help or tips are appreciated.
Jake
Danny Richie
« Reply #407 on: 11 Mar 2014, 03:07 pm »
Danny,
Jake
I cut it back 1.25" from the front edge. I sliced through the foam and pealed it back leaving the damping layer.
The kit will come with the ports.
To clearance the No Rez foam so that it allowed for the port to fit through the middle of it, I adjusted my table saw blade so that it would stick up about 3/8". I then adjusted the side rail so that it would center the blade down the middle of the No Rez piece. I ran the No Rez through it and cut a little saw blade width piece of foam out of it. It cuts like it is not even there. Just be careful and not hang your fingers over the end of the foam in the middle or it might cut through your finger like it is not even there. I then moved the blade over less than an 1/8" and repeated the process flipping the No Rez piece around and running it through both ways. I also lowered the blade by a tinny amount. Continue to move the guide rail over a little each time and the blade down a little each time. In less than a few minutes you can easily hollow out a channel in all four No Rez pieces that go around the port.
Now the port will slide right in.
JakeJ
« Reply #408 on: 11 Mar 2014, 04:20 pm »
Thanks!  Looking forward to getting the remainder of the kit and finishing these up.  I plan to do the 3/8" round over with my router and spray them with some sort of textured coating like you did with truck bed liner.  If I do decide on paint should I primer them first?  The material surface seems so smooth that it might not be necessary.
« Reply #409 on: 11 Mar 2014, 10:00 pm »
hey Jake
Yes, I'd use primer, even if you are  using the bed liner it is still a good idea.  It really helps with adhesion giving the paint something to bite to.
If you're after  a textured paint  in different colors,  DupliColor makes some nice ones
http://www.duplicolor.com/products/texturedMetallic/
I used the dark metallic charcoal  on my OB7's and really like it
-jay
JakeJ
« Reply #410 on: 12 Mar 2014, 04:44 pm »
Hi Jay,
Thanks for the tip and the link.  Three vendors in my area makes it easy to buy.  Now I can't decide whether to go with the Graphite or the Charcoal.  Looks like the paint is a finer texture than the truck bed liner, eh?
Jake
JakeJ
« Reply #411 on: 12 Mar 2014, 07:36 pm »
Gents,
My sheet of No-Rez measured 13.25 x 23.75.  I used Visio to create a template for cutting the sheet into the required pieces for the kit.  Note that 4a & 4b make up one area for the upper section of the cabinet.  Grey and Blue shapes are 7" x 3.25" for the middle and lower sections and the Green are 7" x 3.5" for the upper section with the driver.  Don't forget your 1.5" cutback for the driver magnets and the "V" groove for the port tubes.  Hope this helps.
Oops...I made 4b 1.25" wide.  It should only be 3/4" wide x 7" long.
« Last Edit: 13 Mar 2014, 08:10 pm by JakeJ »
« Reply #412 on: 13 Mar 2014, 04:26 am »
Jake
Yup, had the same  decisioin.  Ghe graphite is quite a bit darker if I remember correctly . In direct light,  the charcoal can actually almost look silver if the light hits it right,  in other light, it looks  very dark.  I lied the  way it picked up the light which  was why I went with it plus I wanted the  contrast between the grills and the baffles.
The texture is a bit smoother than the spray on bed liner .  Rember ,  both these  products won't  hide seams very well so make sure  you've done the best job possible  on the seams if yo don't want them showing.
-jay
JakeJ
« Reply #413 on: 13 Mar 2014, 04:01 pm »
Yeah I noticed when I test fit my cabinets there are edges with 1/64" of overhang and some slight spots where the pieces don't quite match up.  I figure I have a bit of sanding to do.  Any tips on products to fill any gaps or low spots?  The 3/8" round over won't take the overhang out, 1/2" would but I don't want to cut into the joints.
Thanks again for your advice,
Jake
Danny Richie
« Reply #414 on: 13 Mar 2014, 04:44 pm »
Jake, I am pretty sure Ben cut them that way on purpose. A sander will knock those edges off real easy. But if the overhand was the other way around and you had to sand a little off of a side panel to level match the edges then that would be a lot of work.
JakeJ
« Reply #415 on: 13 Mar 2014, 06:46 pm »
It's all good, Danny.  Making a cabinet this small must be a challenge to cut in the first place.  That's what they make power tools for.   :wink:  When I go to glue them up should I leave the front or rear baffle off for final assembly?  I haven't built a speaker kit since the days of Speakerlab so that dates me just a bit.
Apologies if my post sounded like a complaint.
Danny Richie
« Reply #416 on: 13 Mar 2014, 07:06 pm »
The compensation network is just small enough to slide through the woofer hole and screw to the back wall. But it would be easier to mount and wire with one baffle off, the rear baffle.
randytsuch
« Reply #417 on: 13 Mar 2014, 07:37 pm »
Any wood putty should do the trick.  I would go lighter colored, but since you're painting I'm not sure how much difference it will make.
« Reply #418 on: 13 Mar 2014, 08:03 pm »
Wood filler, primer putty, and bondo have all  been used successfully .
For those over hangs,   a flush trim bit in your router should  do the trick nicely .
After you have the joints/seams  looking good,  shoot some dark primer over them , quckly block sand   and see if any  seams  show up.  Repeat if necessary.  I'd wait and do the roundover  after  all this is done so you aren't sanding "into" it.
-jay
JakeJ
« Reply #419 on: 13 Mar 2014, 08:29 pm »
Thanks for the tips, fellers.  That makes more sense, leaving the back baffle off for final assembly and likely the way most mfrs do it.
I have worked with wood putty and bondo before so they both make sense.  I did realize sanding after rounding would be a bad approach so the round over will be last before prime and paint.  I also agree the Graphite color looks dark in the tiny sample square on their website.  The Charcoal will blend nicely next to my Samsung SyncMaster P2250 LCD monitor too.
Here's hoping the boat made it OK.
