Logitech UE Smart Radio
0 Members and 1 Guest are viewing this topic. Read 1902 times.
« on: 24 Oct 2013, 05:57 pm »
Was looking for a solution for casual listening of ‘internet radio’ and my music collection for our nice living room that would be smaller and better looking than my audio leftovers.  Part of the challenge was trying to ‘fill’ this rather large open concept space.  Gladly the UE Smart Radio (a feature packed modern clock radio) has worked out very well:
Small; easy to setup (even for me); intuitive in use; unobtrusive; wireless option (of course); supports MP3, FLAC, WAV, AIFF, WMA, Ogg, Vorbis, AAC, ALAC formats from your computer; smart phone apps available; 3.5 mm input; plenty loud enough for our use; and provides decent sound quality on its own (can add powered/active speakers via the 3.5 mm headphone jack).  According to Nature Boy (thanks again) sound quality via the headphone jack is good.  PSB Alpha PS1 would be a good match in terms of size, glossy black curved looks, and subwoofer output option but don’t see the need to add speakers for low level/background listening.  Within range of your wireless router it’s even portable for up to 6 hours from the battery.
For $100, it’s cheap enough (better equipped than Airport Express).  Friendly to use; compact; respectable sound quality that is upgradable; with lots of online music service options (Pandora, Spotify, Last.fm, mog, Tunein, Slacker, Rhapsody, etc.) it also hits my cheerful button too.
Sonny
Re: Logitech UE Smart Radio
« Reply #1 on: 24 Oct 2013, 05:59 pm »
I had one, the sound sucks...sent it back.   :nono:
« Reply #2 on: 24 Oct 2013, 08:07 pm »
Yeah, and I prefer my $7,000 system in the dedicated audio man cave.
It's only $100 and 9" x 7" x 5", what did you expect?   :scratch:
Plus you can connect it to powered/active speakers (with subwoofer?) via the 3.5 mm headphone output and still be C&C guidelines compliant.
randytsuch
« Reply #3 on: 24 Oct 2013, 08:26 pm »
I was thinking the same thing, expectations are key.
nature boy
« Reply #4 on: 24 Oct 2013, 08:46 pm »
I found it a decent streaming radio, it's not meant to compete with a stand alone two channel system.  Headphone out beats SQ of my rockboxed Sansa Fuze and current generation iPod.  It's not bad for casual listening IMHO.  Still like mine :D
NB
