0 Members and 1 Guest are viewing this topic. Read 23976 times.
I currently have a matched pair of RCA red base 5692s in the front end of my Aesthetix Atlas Signture, and they are much better than the stock black base 6H8Cs.Based on Brent Jessee's 6SN7 page, I'd like to tried the metal base Russian 6H8Cs. I think the Lampi DAC uses these tubes.Does anyone have a good source for these tubes?
There are lots of different Russian 6H8C, the only ones that are valuable are the ones with: -black plates-holes in the plates-marked"1578"Recently I have only seen them for sale by ebay seller russhamma, all the other ones either have grey plates or no holes in the plates. http://www.ebay.com/itm/6N8S-6SN7-tubes-Metal-base-1578-MELZ-QTY-2-/221290868977?pt=LH_DefaultDomain_0&hash=item3385f6b0f1I have a pair of metal base black plates but no holes or 1578 marking, they were about $50. All the various metal based tubes are worth under $100/pair except for the black holey plated 1578. I also have some plastic base 6H8C and the black plate metal base tubes are far different construction and sound quite a bit better. I have never heard a "real" 1578.
Wow, you guys and your suggestions! I tried a pair of CBS Hy tron 5692's and the bass was stronger right from the get go. All else was strong as well. A very good tube. Need more time with it.Now I have the short bottle Sylvania's in and they are extremely good. Super detail but very smooth. Literally have 15 minutes in on them right now.This will be tight racing now and requires me to spend an inordinate amount of time evaluating the sound. Probably have my weekend planned now!
Curious as to what you found with the TS BGRP?
Haven't sprung the big dollars to get some of those.
Eventually I will get some. Right now Mark's suggestion for the short bottle chrome tops is just delivering amazing results. Tunes I used to only sample because they would wear on me are now left to play out because I am actually hearing new details I never heard before and they actually sound 'in tune' now. Crazy good stuff, especially (like the Hytrons) the soundstage is out wider than the speakers and most of the time they disappear. Thanks guys!!!
