Lampizator Dac tube rolling experiences and suggestions.
wisnon
Re: Lampizator Dac tube rolling experiences and suggestions.
« Reply #20 on: 22 Oct 2013, 04:34 pm »
Dunno...Scot hasn't sent yet.  I have the holy grail of 6SN7s, the black glass Tung Sol round plates.
Its a 6x5 recti and ECC40s outputs on that DSD Dac!
Tungsram roll is possible for output, so get on it. TungSol/Bendix 5852/Raytheon roll possible for the 6x5 class rectifier tube.
setamp
« Reply #21 on: 22 Oct 2013, 08:21 pm »
Which Sistrum base is recommended for the L4G4?  They have several at a wide range of expense.
Geardaddy
« Reply #22 on: 22 Oct 2013, 08:29 pm »
Any of the stands will be efficacious.  Talk for Robert at SS to review your choices.
Also, he will tell you to lose the rubber feet that came with the unit.  I am going to have mine made without.... 8)
setamp
« Reply #23 on: 22 Oct 2013, 08:32 pm »
Thanks.  I did remove the rubber feet.  One of the screws broke while reversing out but I was able to get most of it out.
wisnon
« Reply #24 on: 22 Oct 2013, 09:56 pm »
Apprentice stand for $369 is what I heard.
wisnon
« Reply #25 on: 22 Oct 2013, 09:58 pm »
Bendix 5852 (6x5 equiv) recti link: http://westubes.com/store2/index.php?route=product/product&filter_name=5852&product_id=65
Note, it uses 1.2ma instead of 0.6m amps used in the 6x5 tubes.
« Last Edit: 14 Nov 2013, 09:49 am by wisnon »
wisnon
« Reply #26 on: 23 Oct 2013, 07:31 pm »
Nice tube talk in this article:
http://www.6moons.com/industryfeatures/btb/1.html
except:
Okay, but you inventory much which would seem of interest to the high-end valve lover. So what’s up with the NOS trend? I mean, really, isn’t it mostly retro? Telefunken simply looks cooler than Sovtek stamped on the glass? Or are there bona fide advantages of quality and sound? Are we really to believe that valve quality and production processes have devolved over time?
Upper right: Not for sale. BTB's oldest valve dates back to the 1920s.
The explanation is simple. In the 60s when valves enjoyed their halcyon days, the average German income was about 500 Deutsch Marks and an EL34 of the era sold for 15DM. If you transfer that relationship to 2012, an EL34 still sells for about €15 whilst the average income has come up to €3.000/month. It’s easy to see that tubes today are far more affordable. Hence the inverse is true too – price pressures on manufacturers are much higher today. Because valve production remains about 90% manual, you can’t compensate with automatization. In the past selection was much tighter and rejection ratios were far more generous. Today things make it to market which would have been trashed then. That’s why the quality of vintage valves tends to be quite high to make NOS much more than just a fascination with retro.
EscritorJuan
« Reply #27 on: 8 May 2015, 03:17 pm »
THe Bendix 5852s are interchangeable. Personally I do not like them. The 6x5 Tungsols with Staggered plates are my favorite. Just as detailed as Bendix but more musical IMO. If you shop around you can find them cheap.
I actually emailed Lukasz Ficus about a recommendation for a good 6x5 rectifier tube, and he said specifically to avoid the Bendix, as using it would require some modifications in the circuitry to accommodate it.
ted_b
« Reply #28 on: 16 May 2015, 03:28 pm »
How does one tube roll an Amber DAC?  A good buddy has bought one and wants me to hear it in my system, but first wants to tube roll.  However, Luckasz has a seal on the casing that says (paraphrasing) "breaking this seal voids the warranty".  Is there another entrance to the tube section?
Tomy2Tone
« Reply #29 on: 16 May 2015, 04:16 pm »
+1
Have an Amber coming shortly and plan to roll at least the rectifier tube...
