0 Members and 1 Guest are viewing this topic. Read 8247 times.
ChairGuy, I wondered myself if the bass could be improved by some putty adjustment. There was really a pretty substantial difference in the bass with the two DACs.
Unfortunately I had other business to attend to.
I've noticed that many digital front ends, particularly DACs take 2 or 3 days after being pluged into stabalize. Before that they sound aweful, or at least much below their prime and peak. I assume that the "challenger" as moved to the AC in Brian's system, and was not plugged in for more than a few minutes before the comparison started. I wonder if that fact doesn't invalidate the whole shoot out . . . Comments anyone?
I doubt John or John or Brian care, but just for the record: we tried my Sunfire pre-pro as a gain attenuator for Chair Guy's DAC. None of us seemed thrilled with the performance. Unfortunately, because I am still new to the preamp, & not as familiar with its operation as I'd like to be, I did not know at the time that the signal was passed through ADC & DAC sections in the preamp. I since learned we could have kept the signal in the pure analog domain by using two of the 9.1ch inputs, commonly used for high-def analog sources. I am unsure, but switching to a "pure direct" mode may have also accomplished the same result even with the input we used. The high-def pure analog inputs require the gain attenuation circuits to be comprised of digital voltage control of the output stage amplifiers of the Sunfire pre-pro.
