Nuforce DDA-100 vs IA-7 v3
0 Members and 1 Guest are viewing this topic. Read 4253 times.
Welborne
  • I love open baffle with 100db sensitivity!
« on: 11 Oct 2013, 11:30 am »
Can anyone tell me the difference sonically between these two? I know how IA-7 v3 sounds as I owned it before, sold because I was looking for Stereo 8.5 v3, but then took a detour back to tube, but the sound of V3 keeps lingering  in my mind all these years. Now as i was told the IA-7 v3 has been discontinued. My choice to reenter the budget Nuforce is either DDa-100 or STA-100.
Opinion welcome.
welborne
rustydoglim
    • www.nuprimeaudio.com
Re: Nuforce DDA-100 vs IA-7 v3
« Reply #1 on: 12 Oct 2013, 04:25 am »
If you have high efficiency speaker or in a near field listening position, DDA-100 can sound better than IA-7V3.  It has more details.
Welborne
« Reply #2 on: 12 Oct 2013, 07:46 am »
Thanks Jason for your reply.
My concern is: will the DDA-100 sound as sweet as v3? I had v2 and then moved to v3 and I know the difference and how much more refined v3 is and that is exactly what makes Nuforce stands out from other class D I tried. I was not sure about the DDA or STA and whether they are more v3 type or v2 sound.
charliefoxtrot
« Reply #3 on: 13 Oct 2013, 07:09 pm »
Define sweet. I've lived with the IA-7 V3 for 3 years and just got the DDA-100 the other day. The initiall impression is that the DDA-100 is a tad warmer sounding.
« Last Edit: 13 Oct 2013, 08:33 pm by charliefoxtrot »
John Casler
« Reply #4 on: 17 Oct 2013, 07:44 pm »
Also depending on your speakers efficiency one amp may have an advantage.
That is the IA-7 is more powerful, so would likely sound smoother with less efficient speaker loads.
Welborne
« Reply #5 on: 18 Oct 2013, 09:01 am »
My speaker is 100db/1w Bastanis Mandala open baffle system. Yes, i know, i don't need all those 50w to 100w,  few watts will do but there was something very good about the IA-7 v3 that reminds me of some very good DHT fleawatter like vt25. I was in a bit of a shock when I heard my ia-7 v3 transformed after 200 hours of burn in(I almost gave up...).
Now with the Nuforce STA100 much cheaper than the ia-7 v3, I would like to know if there is an improvement over the now ceased ia-7, or it is step up in refinement. Both have too much power for me anyway.
Welborne
« Reply #6 on: 26 Oct 2013, 08:52 am »
okay, perhaps I should ask my question again properly in order to compare apple to apple.
How sonically different is STereo 8.5 v3 and STA-100?
Both are pure power amp with rca input.
