Auralic Vega DAC
0 Members and 2 Guests are viewing this topic. Read 66448 times.
srb
Re: Auralic Vega DAC
« Reply #200 on: 28 Mar 2016, 06:11 pm »
Are you using Mac or Windows?  Mac won't do DSD256 out of USB - at least not without a driver, of which there is none for Mac for the Vega.
If Dr. C's System listing is up to date, it's a Windows 10 PC.
doctorcilantro
« Reply #201 on: 28 Mar 2016, 06:52 pm »
Yeah I'm using Windows 10. The problem is I'm using the exact same settings for native DSD over USB that works fine with my iFi.  I feel a bit left in the lurch by auralic as it's been almost 4 months the tech I'm dealing with keeps telling me that it works and foobar but I don't see how he's doing PCM to DSD, and he won't tell me.
I have all the SACD plugins for foobar but nothing jumps out to enable PCM2DSD.
I need to locate some native DSD256 content, doubt it will work though. Matt at jriver has been strangely quiet on this, not one reply which is not normal.
I can do DSD512 all day on JRMC21 with the iDSD using PCM2DSD.
Tried all kinds of settings. Vega just blinks 3x trying to do DSD256 and errors out.
doctorcilantro
« Reply #202 on: 29 Aug 2016, 06:08 am »
If you want DSD256 on Windows, I had to install the newest driver which is not listed on the Web Page, but this Auralic Support Page:
http://support.auralic.com/hc/en-us/articles/222588028-AURALiC-USB-Driver-Version-3-34-0-
Using JRMC with pretty good stability in EXACT clock mode for PCM2DSD256
