0 Members and 1 Guest are viewing this topic. Read 17230 times.
Russ, "0" level compression is not "no compression". Zero is just the lowest level of compression. FLAC also has (with newer FLAC decoders) a "no compression" option which some say delivers wav quality with the benefit of universal metadaa support, etc...
I'm still baffled by why people are ripping to WAV and storing their music that way. Don't you read earlier posts in this topic? rip and store as FLAC, save space, speed access and have good tagging, then convert to WAV and play from memory if you think WAV sounds better??
Not trying to stir the pot, but… anyone else hear a distinct difference between WAV files and FLAC files encoded from the WAV files?...
Hi Barry,Possible trouble in playback system. May be you check for some old FLAC library or versions with bugs.May be playback part (after decoding) has differences for WAV and FLAC.Possible many reasons, that need learn.But digital content WAV and FLAC fully identical theoretically and practically. (I used last on December 2014 flac library version)Best regards,Yuri
