0 Members and 1 Guest are viewing this topic. Read 5042 times.
I don't really want to create a permanent network, just move a bunch of files from one computer to another. Physically they're only two feet apart. I want to transfer a whole bunch of wav files from machine A to machine B.I'd much prefer not to rerip them as EAC isn't really fast, plus I don't want to have to type in all the track info again (I know EAC can connect with an online database, and I do this on PC#1, but I don't wish to have PC#2 connected to the 'net).
I wondered if simply connecting them with CAT5 cable would work; can I merely unplug from the 'net and connect the two PCs thru their 10/100 cards? That would be very simple & elegant if it works that way.
Rob,If I remember you have a firewall for your internet connection. Many of these have a 4 or 8 port switch. If this is the case, just plug both machines into the switch and it will hand out an IP address to each machine. With XP you will have to enable file sharing. It's turned off by default. Some info on how to do this: http://www.practicallynetworked.com/sharing/xp/filesharing.htm
