0 Members and 1 Guest are viewing this topic. Read 18073 times.
I tried out the ambiophonics app on the iPad.The first thing I wondered about was there didn't seem to be any calibration. Upon reading about miniAmbio there is a calibration step.I only listened to one song with the ambiophonics app.It seemed to add a bit of delay/echo that seemed a little off. It really brought out the background ambience of the recording, made it louder, and pulled it forward in the mix. It was like hearing a completely different mix of the song. I did not think this new sound better in any way, just very different and a little bit wrong with the delay. The drums also seemed to lose their snap.The app did have some sliders to adjust, but I had no idea what to make of these adjustments. I could tweak them and the sound would change a little, but I don't think this is something that should be done by ear.
Well, this topic doesn't belong in the Cheap and Cheerful HiFi circle unless someone can propose an ambio system under $400. However where to put it is somewhat of a quandary. Hi Rez? Solid State? The Lab? Any suggestions?
Acoustics circle perhaps?
The thought was to let it die a natural death and forget about it. And I think the downloads were free so nothing violated guidelines. Kinda silly to move it three years later.I've heard a few ambiophonic recordings over headphones and liked some of them, others not so much. If there was a grand resurgence in the marketplace I would purchase a few, but as of now the titles are so limited it doesn't pique my interest much.
I am expecting delivery of my Gate tomorrow. They went back on sale for $33ish so I had to grab one. am going to run the 3.5mm out to RCA's and hook them up to the analog inputs on my Harman Kardon HK3490. I see the Gate has volume but it's not an amp nor is it a pre-amp so what is the volume function for? What level should the volume be set at?Is the volume control effecting the sound quality in a negative way?Thanks!
I want to use a physical barrier approach to Ambiophonics and wonder if I could ask you some questions about this approach please. My dedicated room is 4.2m x 3.86m x 2.4m with speakers and chair positioned using ‘The Thirds’ set up which makes them 1.5m from my ears and just over 1.5m apart. The room is very well acoustically treated with lots of bass traps and panels. I use one panel close to the outside of each speaker to prevent side wall reflections. This gives me a pretty strong central image and sound up to the speakers but not beyond them. I listen mostly to studio recorded pop which mostly sounds very good, and occasional classical, which sounds OK but could be better!I’ve read about Ambiophonics but most of the papers concern RACE. I’ve also read Floyd Toole’s thoughts on the phantom image amongst other things.My idea was not to use one central panel going up to my nose to prevent crosstalk but to use one panel on the inside of each speaker, carefully placed so that I still hear the direct sound but not the crosstalk.My questions are:1. In my circumstances, notably my prevention of side wall reflections, is it necessary to move the speakers closer together as you normally recommend?2. What frequency range should the absorbent panel cover? You mention in one of your papers that for ambiophonic purposes nothing much goes on below 400Hz, whilst I understand BACCH doesn’t do anything below 94Hz.3. Is there any loss of loudness when preventing crosstalk?
