Another Rookie Build (A/V-3, A/V-3S, A/V-1RS and X-LS Encore)
0 Members and 1 Guest are viewing this topic. Read 5493 times.
Danny Richie
Re: Another Rookie Build (A/V-3, A/V-3S, A/V-1RS and X-LS Encore)
« Reply #20 on: 15 May 2014, 04:29 pm »
So...where did you get the cool GR logos?
The logos come with those kits. They come in all of our kits except the X-Series kits.
mlundy57
« Reply #21 on: 15 May 2014, 07:07 pm »
Thanks all  :D
Mike... I cut both veneers at the same time and taped them together.  The baffle is all one piece...like normal.
Scott,
So you just spliced two pieces of veneer together the same way you would join any two pieces, these just happened to be contrasting and you cut the joint in an arc rather than a straight line? Very interesting and stunning results. I will have to remember that.
Mike
Scott Trebble
« Reply #22 on: 16 May 2014, 12:35 am »
That's right Mike.
I taped down the two veneers with an overlap, made a compass type stick with an exacto blade glued in it, then took multiple light strokes, as it was across the grain.
I did a test piece first, and it worked out better than I thought it would.
Always cool to try new stuff :-)
Bob in St. Louis
« Reply #23 on: 16 May 2014, 01:42 am »
That's very clever Scott, well done Sir!  :thumb:
