0 Members and 1 Guest are viewing this topic. Read 101383 times.
I've had a RX-ES1 for about two and half years. Initially I wasn't running the 5.1 some time after purchasing the unit. I connected a couple of small speakers to the rear and started trying out the 5.1. It worked fine after a while and then the RX-ES1 developed crackling sounds as soon as you turn it on...
Quote from: mmarchant on 11 May 2006, 11:09 amI've had a RX-ES1 for about two and half years. Initially I wasn't running the 5.1 some time after purchasing the unit. I connected a couple of small speakers to the rear and started trying out the 5.1. It worked fine after a while and then the RX-ES1 developed crackling sounds as soon as you turn it on...Hi there, is this topic still active??I do own the same system (got it for few years now already) and am very satisfied with it!But I have the exactly same problem as you do. Only diff. is that I am using the default JVC speakers that came with it (small satellites).I am using digital inputs as well as analog. From my experience once the crackling sound starts, if I switch through the diff. surround options (e.g. crackling starts when I'm in "all channels stereo" and switch to "stereo" and then to "play movie" and so on...) the crackling sound eventually goes away on one of these other surround setting.Also sometimes if I switch the sources (e.g. crackling starts when I'm in "TV" and switch to "DBS" then "DVD" and then "FM/AM" and then back to TV) the sound goes away as well. But it does start again irregularly!I do have the crackling sound in both analog and digital input...have you managed to solve the problem?Would be glad for any input.-M-
