0 Members and 1 Guest are viewing this topic. Read 21076 times.
...But - - - if you record yourself talking in a normal live room and then play the recording back in that anechoic chamber, it will sound just fine. The recording includes the acoustics of the original live room along with your voice...
Well Nyal, what would have better low frequency room damping than an an anechoic chamber? Are you telling me that we want great damping at some low frequencies but not at higher frequencies? Where is the appropriate frequency where we should switch over from damping to reflective?
Obviously we can't have a perfect interior listening room in a rational private home, but the goal should be to get as close to this as reasonably possible. By the way, when I say stiff room, I am meaning something like concrete - no flex or mechanical resonance at all. Room node reflections and boom control requires careful room dimension design. I have no problem with double layer wallboard with careful inert bonding layers. It is a step in the right direction at some frequencies, but there is much more to solving the problems then this.
Yes. And the answer is the specific Schroeder Frequency of the given space.
would be below the transition zone (poorly approximated by the Schroeder frequency, probably around 300-500 Hz, depending on room size). Above that, gradual switching over would depend on loudspeaker directivity
I recommend putting some insulation between the joists above the drop ceiling. Worked for me.
....A solid core door to close off your room will help too.
Back to my OP. In my particular situation(drop ceiling and french doors), is GG 'really' necessary to damp the sound further, or would it have little effect? Should I have something between the sheets of DW, or just hang the 2nd layer right over the first overlapping existing joints, mud and tape and call it a day? Keep in mind, I'm not after total isolation, and what I have (including 2nd layer of DW) will be good enough. - Rick
I don't see you being able to take full advantage of the double drywall unless it has been isolated from the structure on hangers and each layer separated by a viscoelastic compound. That's my experience and those of many others in my neck of the woods.
