Manic Moose (S2) - BDP's third major firmware release
0 Members and 2 Guests are viewing this topic. Read 613038 times.
keithjacksontucson
DSD files
« Reply #820 on: 16 Sep 2014, 01:05 am »
does the new firmware allow the BDP-2 to play any of the folling file types , DFF, DSF, ISO?
unincognito
    • bryston.com
Re: DSD files
« Reply #821 on: 16 Sep 2014, 01:38 pm »
dff and dsf should play, but will require a usb Class 2 Audio dac capable of decoding DoP.
Chris
bk12
Re: Manic Moose (S2) - BDP's third major firmware release
« Reply #822 on: 18 Sep 2014, 01:29 am »
Is there a way for users to add stations to the B-Radio themselves?
dgarratt
« Reply #823 on: 23 Sep 2014, 10:09 am »
Hi Chris,
Quick questions for you...I'm considering purchasing a bdp2, wondering if the bdp would appear as a renderer if I was to install a generic dlna control application on my iPad or iPhone. If not..why? Can and will this implemented in the future? I'm not a fan of the mpad or mpod applications, to me they look dated.
Thanks in advance.
gdayton
« Reply #824 on: 23 Sep 2014, 02:02 pm »
Hi Chris,
Thanks in advance.
Yes, in the "services" menu, you can can elect to turn on the DLNA/UPNP Renderer option.
keithjacksontucson
Beginning of songs cutting off
« Reply #825 on: 23 Sep 2014, 07:19 pm »
I'm using 2.05 08-18-2014
Using with BDP-2
not sure if anyone is having this problem
and even if it's the new firmware or if it's the player
The fiirst second or two of songs , usually the first song in a playlist
is being cut off, so the song starts with the beginning cut off
Is this just me?
unincognito
    • bryston.com
Re: Beginning of songs cutting off
« Reply #826 on: 23 Sep 2014, 08:57 pm »
Using with BDP-2
Is this just me?
I suspect its your storage, if the issue occurs and you click the track again does the issue repeat?
Chris
dgarratt
« Reply #827 on: 23 Sep 2014, 10:46 pm »
Can anyone tell me where this new firmware is available for download? Looking at the BDP-2 page on the Bryston website it only seems to list a version from 2012.
Thanks in advance.
keithjacksontucson
skipping the beginning of tracks
« Reply #830 on: 24 Sep 2014, 11:41 pm »
thanks Chris
no it doesn't skip when I reset the track
So storage makes a difference?
It's my toshiba hard drive
I'll try the Seagate.
Is ther anything to look for in a hard drive
to avoid the skipping problem?
keithjacksontucson
skipping beginning of track
« Reply #831 on: 24 Sep 2014, 11:50 pm »
I t doesnt do it  with my Seagate drive
what makes the difference?
keithjacksontucson
skipping beginning of tracks
« Reply #832 on: 25 Sep 2014, 12:07 am »
also do you have a practical brand preference of USB external hard drives?
unincognito
    • bryston.com
Re: skipping the beginning of tracks
« Reply #833 on: 25 Sep 2014, 03:17 am »
thanks Chris
Yah there are a number of things that cause this, i find it happens most often when you use a NAS but the sleep function in some drives can also cause it to occur.  I just more or less expect and just tap the first track a second time after its started (depending on the source).  Drive manufacturers change there firmware year to year and just because you buy seagate, western digital or other name hard drive doesn't mean it contains a drive by that manufacturer.
cheers,
Chris
unincognito
    • bryston.com
« Reply #834 on: 25 Sep 2014, 03:19 am »
Hello everyone, for those who are not yet aware we have started our own forum to provide support for our products.  Hopefully by having our own support forum where people will be able to create new topics in categories related to the product it will make finding answers easier.
So, please join us over at http://support.bryston.com
Chris
Marius
« Reply #835 on: 12 Oct 2014, 02:53 pm »
HI Chris,
Will you somewhere soon fix the scrolling problems in MM? Scrolling down to the bottom of the folder list in Mediaplayer is impossible on Safari/Mac right now. Unable to reach Wagner.... making my days really hard to endure ;-)
Please fix!
Thanks, Marius
unincognito
    • bryston.com
« Reply #836 on: 15 Oct 2014, 04:31 am »
HI Chris,
Please fix!
Thanks, Marius
I didn't realize this was a problem, i have always been able to reach the bottom, would you mind sending a screen shot, perhaps i am misunderstanding or missing something?
Chris
Marius
« Reply #837 on: 15 Oct 2014, 05:36 am »
Hi Chris,
I will, I've already sent you some Screenmovies per mail.
Please check post 797 also.
Cheers Marius
Chris
Marius
« Reply #838 on: 15 Oct 2014, 05:24 pm »
Hi Chris,
I can't get a screenshot to show the issue, since it keeps scrolling back automatically.
AC won't allow posts of screenmovies though.
The issue is that scrolling down to the bottom of a long folder list, the menu/command area scrolls out of the top of the main window, and since MM wants to keep that in place, pushes it down again, but also pushes the bottom folders down. In my case 4 folders.
Hope this is clear enough, if not let me know please. Ive also resent my mail of september 3d, please find it in your mailbox.
Marius
Hi Chris,
Cheers Marius
unincognito
    • bryston.com
« Reply #839 on: 16 Oct 2014, 01:34 am »
Hi Chris,
Marius
Hi Marius,
I havn't received any email from you, perhaps try emailing me with out the video attachment and I'll reply using my iCloud for you to send the video to.
Cheers
Chris
