Survey - What Speaker Cable do you use with your Bryston amp
0 Members and 1 Guest are viewing this topic. Read 21492 times.
Angelo62
« Reply #40 on: 30 Mar 2005, 02:16 pm »
Transparent Super. They work very well.
Angelo
Alfalfa
« Reply #41 on: 30 Mar 2005, 03:09 pm »
I'm using 20 centimeters of Van den Hul Magnum
geldis
« Reply #42 on: 1 Apr 2005, 06:35 pm »
Hi :D
In this moment I`m using Harmonic tech Pro11. I´m not sure this is the best choice. I think something is missing in the top. I will try an another cable soon.
Regards
geldis
BeeBop
« Reply #43 on: 2 Apr 2005, 12:38 pm »
I am using 6 feet of DH Labs Q-10 cables between my 3BSST and my ACI Sapphires. These are the speakers that ACI uses to voice its speakers and they work very well. I was using 12 guage Radio Shack copper strand wire (well Radio Shack calls it audiophile), and the Q-10s really took it up another notch - much better detail in the mids and punchier bass, with sibilance reduced to almost zero. One thing I did find with the Radio Shack cables - the shorter the better. I was able to get better performance out of these by reducing the length from 15 feet to 8 feet. The difference was noticeable, although nowhere near what I am able to get from the Q-10s.
