0 Members and 1 Guest are viewing this topic. Read 18839 times.
How is the soundstaging on the Cirrus? Is it deep and wide? Would it trick someone to thinking the listener is at the middle of a concert hall when called for? Thanks.
Thanks for the reply. I didnt think the room dimensions were important so I just said it off the top of my head. The actual dimentions are 13 x 13.6 x 9.5. I have a door that leads to the kitechen, and double french doors at the back that I can keep open as well.How is the soundstaging on the Cirrus? Is it deep and wide? Would it trick someone to thinking the listener is at the middle of a concert hall when called for? Thanks.
LOL I never knew you used to work for Stereomojo Ryan. Very interesting!!! Love reading Stereomojo stuff.
I am currently torn between the 3 speakers. Did anyone have the chance to hear all 3? What would you recommend?Gonna run it with OPPO 93 => Monarchy DIP Upsampler => Nad M51 => Job 225 w/ Audioquest cables.thanks!
First off, my opinions are just my opinions ... and obviously I'm biased. But I have to assume that by asking here, you're hoping to hear my opinion. The Cirrus had a very simple goal, to be the best 2-way monitor possible. We use the AudioTech C-Quenze woofer which we think is the best on the planet, the RAAL tweeter which is also the best, and put it all in the best cabinet we know how to build ... and with the best crossover components, and years of voicing. We thought of everything with that design, and it shows in the result. In a properly setup room they will completely disappear and give a seamless wall to wall soundstage. They're incredibly articulate and resolving, but never cross the line to harsh or fatiguing at all - they should you everything in a recording but without any edge. One of the Cirrus' unique capabilities is, based on your mood, they can either excite you or relax you. I've heard the MicroOnes a few times now at shows, on different setups and different rooms. I don't know what they're selling for now, but at their $2500/pair price they were a good buy. They do image well and have excellent low level detail retrieval. In a lot of ways they're a very good speaker. But they are a bit edgy and cold for my taste, but that could be worked out somewhat with equipment pairing. Their AMT tweeter just isn't as good as the RAAL, it's good but not RAAL good ... some hash can creep in on more complex material, and at higher volumes. With the RAAL that just doesn't happen. And I felt the bass was a bit chuffy and one note, not much tonal density to the bass and makes everything from 40-80hz sound the same basically. I'd imagine with a high pass filter cutting off below 80hz and a pair of subs, the MicroOnes could make for a great setup. BTW, the MicroOnes are just a basic MDF box with a laminate stuck on the outside that looks like stacked ply. The Cirrus is real stacked 13-layer Baltic Birch ply, no MDF anywhere. The Seas Pendragon isn't going to be in the same league in terms of detail retrieval, transparency, soundstaging, articulation, etc. I haven't heard them, but what drivers you use essentially set a hard ceiling for a speakers performance capabilities. Your job as the designer is to get 100% out of the drivers through cabinet and crossover design. And those drivers just aren't capable of the same level of performance as the Cirrus (or even MicroOne) drivers. Add to it very resonant cabinetry and you have a speaker that will probably do good at sounding big, but only average at everything else. Also Tekton has quickly established a reputation for taking liberties with their specifications, they aren't 95db .... and don't go flat to 30hz, no matter what they say. That size cabinet (~2.6cu/ft), and those woofers will have an F3 of 44hz, and a pair in parallel with some baffle step compensation will be 92db sensitive at best. Like I said, those are just my opinions. The Tekton approach is not my cup of tea at all, low resolution drivers in a big honky box. The MicroOnes are better, but honestly are more competition for our Stiff Breeze and not the Cirrus.
What I thought you already ordered your speakers more than once.. Audioholics http://forums.audioholics.com/forums/loudspeakers/86296-tekton-enzo-most-inexpensive-speakers-league-high-end-speaker.html
What I thought you already ordered your speakers more than once.. Audioholics http://forums.audioholics.com/forums/loudspeakers/86296-tekton-enzo-most-inexpensive-speakers-league-high-end-speaker.html[/quoteJust shopping around. I honestly started posting just to troll there at one point. They wholeheardedly believe that amps and pre amps and dac's dont make a difference which in mind is as stupid as it gets. Anyway, when I first began posting there it was more for home theatre and movies, but in midst of all that I started to become more of a music lover so circumstances changed alot from the initial post... Just didnt care to explain there because I was trolling most of the time.Anyway, Ryan thanks for the comment!
Just shopping around. I honestly started posting just to troll there at one point. Anyway, Ryan thanks for the comment!
Guys, I bet most of us have trolled somewhere at some point ... just messing with people to get a rise out of them. I know I did plenty in my younger years, so let's not get all judgmental.
I've only heard the MMMircoOnes and the Cirrus, and well I now own the Cirrus for what that's worth. I MMM are nice they just seem very limited, I think loud and low (and I really only mean like 120hz) would be impossible for them to pull off, also the tweeter is just ok. Disclaimer, I'VE NEVER HEARD THE TEKTON, however the driver layout looks like a sonic nightmare.
What???The thing does and honest to goodness 40hz and that is solid Heil tweeter.Never heard the reputed Cirrus which could be better, but dont disparage the Micros unfairly!
