Which makes the bigger statement?
0 Members and 1 Guest are viewing this topic. Read 7097 times.
jaywills
Re: Which makes the bigger statement?
« Reply #20 on: 20 Sep 2013, 02:25 pm »
Yow, I live in Little Rock.  Any chance you can talk you customer into an audition?  thanks
Don_S
« Reply #21 on: 20 Sep 2013, 02:26 pm »
Cudas should be in screaming yellow.   Purple is for grapes.
What color will the screws be in the front of the speakers?  The black holes spoil it for me.  I am thinking the screws would either have to be white or silver.  Something that does not draw attention.  Otherwise the speakers look killer.   :thumb:
I love the speaker but the 70-72 cuda in purple is one of the greatest cars ever built(if it's going to have a hemi).
Pete Schumacher
  • It's all in the pursuit
    • Vapor Audio
« Reply #22 on: 20 Sep 2013, 02:35 pm »
When you place your order Don, we can make them any color you want!!!   :wink:
Bob in St. Louis
« Reply #23 on: 20 Sep 2013, 02:52 pm »
Even Purple!  :thumb:
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« Reply #24 on: 20 Sep 2013, 04:24 pm »
Usually, they are thrilled to show them off to other audio enthusiasts.  I wouldn't think that would be a problem, but we'll chat with the owner just to make sure.
You could also PM Harley52 directly and invite yourself over!!
Mike B.
« Reply #25 on: 20 Sep 2013, 05:13 pm »
A plum crazy mopar is my choice. There is this shop in town that does a car show called Graveyard Carz. Their specialty is restoring mopar cars from the 1960's and 70's.
