Platinum bypass caps
0 Members and 1 Guest are viewing this topic. Read 1215 times.
bdp24
« on: 4 Sep 2013, 11:25 pm »
Danny---The order form for the N2X and N3S kits have a box for ordering the Sonicap and Mills resistor upgrades, but not for the Platinum bypass caps. Is that because you have none in stock and won't for the foreseeable future, not because you don't recommend them for that application? Can they be added to the x/o later, when production of them resumes?
« Last Edit: 5 Sep 2013, 03:44 am by bdp24 »
Re: Platinum bypass caps
« Reply #1 on: 5 Sep 2013, 05:32 am »
From  what I gathered from  Sonicraft,   there may not be any more production of the platinums.
I think you'll find that Danny probably has  the.022 uF platinums in stock and if not,  Sonicraft still had them listed when I was looking at tthe site the other night
-jay
Danny Richie
« Reply #2 on: 5 Sep 2013, 12:50 pm »
I have them in stock, just not on the website as an option.
Just put into the comments section that you like to add them and I can add them to the order.
