Suggest a center channel
0 Members and 1 Guest are viewing this topic. Read 11662 times.
this_is_vv
Re: Suggest a center channel
« Reply #20 on: 5 Sep 2013, 06:14 pm »
I don't have personal experience with the Revelators to be able to make a worthy suggestion.  I do prefer the appearance of the uncoated versions which don't have shiny cones.
The Salk Sound suggestion is sweet!  I get the downside of the MTM versus the WTMW but the MTM looks more sleek and is significantly smaller.  Plus, I think it would be easier for you to build/complete a MTM version.  Jim Salk may even be able to create his SupercCharged Song Center for you with Revelators if you desired that.
Have you considered trying a cheap center channel alternative to see, in your setup, if the driver compliment matters all that much?
I am open  to idea, any input you can provide...there are some really nice cheap centers and i dont know
TF1216
« Reply #21 on: 5 Sep 2013, 06:49 pm »
Why not see if you can try one of Dennis Murphy's offerings before leaving the east coast?  http://philharmonicaudio.com/folio-me/html/Phil%20Pages/bookshelf.html
this_is_vv
« Reply #22 on: 5 Sep 2013, 06:51 pm »
well for center channel he has send it too SALK...i guess my best bet is SALK , Selah or vapour audio...
V
TF1216
« Reply #23 on: 5 Sep 2013, 08:20 pm »
V
I think Dennis lives very close to you.  Maybe he has a center channel at his disposal he can lend you to try out.
Mudslide
« Reply #24 on: 9 Sep 2013, 02:48 am »
Dennis has designed an MTM center sold through a third party.  It uses a Fountek ribbon tweeter and SB Acoustics midwoofs (designed by former ScanSpeak designers).   It matches his Philharmonitors.  See Dennis's website at
www.philharmonicaudio.com ... or http://www.alexissound.com/  ...but the seller is possibly out of stock atm...awaiting tweeters delivery.
G Georgopoulos
« Reply #25 on: 9 Sep 2013, 06:09 am »
Seems like i keep on asking people what is best for me...Now my left and right are doing great . I have a DIY center channel which is making me really hard to listen.
Put a really big amp and speaker in the center channel that will solve your problem... :green:
