0 Members and 1 Guest are viewing this topic. Read 112266 times.
Thanks Brett & Holzohr: The Schiit Loki seems it will do the trick. And also from the DSD database, the iFi iDSD portable DAC (http://www.ifi-audio.com/en/iDAC.html) looks even better, handling native DSD input, as well as DSD128, although here in NZ the price has morphed from the $169 (couldn’t see where you can buy it for at that price.??) to $450. And if the SBT still won’t handle the converted DSD files, I can also run them directly from a PC. I’ll wait to hear how you get on Brett.Jon
The Loki works just fine with the EDOed Touch.
That's good to know. What does Loki do when sent a PCM file?
bprice... How does the Loki handle DSD, soundwise? "Better" than the TEAC?
Hello Deribas,if creating DoP files should be a problem (I am not a MAC user), have a look at www.daphile.com It is a small slim "OS" based on Gentoo and LMS 7.8.0. It offers converting DSD -> DoP on-the-fly. I use it on a small fanless Shuffle barebone (with a SSD) for a week. All I can say is: Advantage compared to the SBT is also USB-hotplugging and DSD128 playback. The "poor" SBT is used as display for the USB DAC at the moment. Surprisingly (to me) I could chose the USB DAC as extern player in the SBT menu.RegardsMario
then convert DSD to DoP FLAC
