0 Members and 1 Guest are viewing this topic. Read 112298 times.
I believe I got the conversion to flac done, but I still don't know why I was having problems. My fix was to simply move to another computer. My suspicion about being unable to convert to flac on the 1st computer is that the problem had something to do with flac.exe and not foobar2000. With that being said, I still cannot get DSD through my DAC. I believe the problem is with the DAC itself. If I understand correctly, the TEAC UD-501 only does DSD through the USB input and the TEAC's USB input will not work with EDO. So, there you have. I'm screwed. What I'm getting now utilizing the coax out on the Touch shows up on the DAC as 176.4 PCMIf anyone knows of a way to get the UD-501's USB input to play with EDO, I'd love to hear about it.
Unfortunately (strangely?), the TEAC reads the DoP file as PCM 176.4. I don't even see how this is possible. Maybe you guys have some ideas?
The DoP file is formatted as 176.4 PCM so that makes sense. The 176.4 PCM DoP file is a taxi cab for the DSD file. Once the cab arrives, the DoP function in the DAC is supposed to pay the fare, open the door, and invite Mr. DSD to step outside and shake his groove thang.Just curious, does your Teac currently play DSD from a Mac or PC?Russ
Maybe I'm not understanding, but it's not a 176.4 PCM file. It's a DSD file wrapped in a flac container...right?
Russ,this is a great primer! Thanks! If you don't mind may I use this (with full disclosure to you, the author) in my revised SACD Ripping Guide? I need to do major revisions (mostly to the after-ripping-now-what portions) and this would be a great addition. I will wait until it "fleshes out" with any opinions, changes, adjustments or feedback. Ted
Thanks for the response. I'll keep working on it.
Have you tried your pc and USB (with Jriver, for example) just to get DoP working?
So JRIver bitstreaming must be set to "off"?
Guido, I found this in the EDO compatibility list https://docs.google.com/spreadsheet/ccc?key=0AqiK6WHnz5FHdEtlalVRb29pX3N2WXhfMlAzNmFMZnc#gid=0 for your DAC:
Guido, I found this in the EDO compatibility list https://docs.google.com/spreadsheet/ccc?key=0AqiK6WHnz5FHdEtlalVRb29pX3N2WXhfMlAzNmFMZnc#gid=0 for your DAC: "SPDIF and Optical - everything works. For USB, user must set EDO Buffer size to any setting except "Default" or "Very Large + Randomise CPU", then let the Touch reboot to reacquire handshake with the DAC or else sound will be distorted."
