BDP1 Controller for android
jjc1
« on: 26 Aug 2013, 05:38 pm »
  Hi everyone. I just purchased an android phone. Is there a controller for the BDP1 available as an app?
ttsto
Re: BDP1 Controller for android
« Reply #1 on: 26 Aug 2013, 10:14 pm »
I use MPDroid, an older version (from 16.10.2012) than is available now on Google Play. I was unable to set current version to display local cover art.
See also this thread from post 335
Later edit: see this site for the versions
« Last Edit: 27 Aug 2013, 04:34 am by ttsto »
ronman
« Reply #2 on: 30 Aug 2013, 08:01 pm »
Hi
I have been using MPDroid as well for quite a while (various versions). None of them seem to support album art. I read somewhere that the developer doesn't bother with album art so he didn't address that bug. Stable program though.
ttsto
« Reply #3 on: 31 Aug 2013, 06:30 am »
Maybe this will help...
My BDP-1 is setup with static IP address, for example below I will use 192.168.1.115 (from PC interface: Settings, Network, check Static, enter desired IP address, hit apply, restart BDP)
My music is on USB drive with label "Music" organized on folders Artist\[year] Album. Each folder contains cover picture file "cover.jpg", usual size 450 x 450
I use MPDroid version 1.03.1 (16.10.2012)
I use following settings on Mpdroid:
 Download local cover art - checked
 Path to music - http://192.168.1.115/music (is case sensitive, will not work with Music)
 Cover filename - cover.jpg (case sensitive)
This was the only combination I could get to display local cover art.
« Last Edit: 31 Aug 2013, 07:17 pm by ttsto »
jjc1
« Reply #4 on: 9 Sep 2013, 09:13 pm »
  How does one clear the playlist when using the Droid MPD?1
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 9 Sep 2013, 09:58 pm »
Which version of droid - HD?
James
jjc1
« Reply #6 on: 10 Sep 2013, 02:46 pm »
  Thanks for looking James but I found the "remove all" button.
