WiFi Enabled Thermostat
0 Members and 1 Guest are viewing this topic. Read 1340 times.
Bill A
« on: 24 Aug 2013, 03:45 pm »
I need to replace a couple of thermostats in the house and the WiFi enabled ones are intriguing.  They offer the possibility of setting them with a better, more intuitive interface, and remote control, but I don't really know anyone that has first hand experience with any, web reviews notwithstanding.
Have any of you experence with these?
Bill
P.S. I did see an earlier post regarding Siri and whole house control, but not much on WiFi thermostats.
kc8apf
  • Are you sure what side of the glass you're on?
Re: WiFi Enabled Thermostat
« Reply #1 on: 24 Aug 2013, 04:16 pm »
I've had a Nest since they came out. Its a wonderful device. Figures out when no one is home and changes to your away temps. Starts the heater or A/C before the scheduled time which is great for having the house cold while you sleep but the right temp when you wake up. Its fairly pricey but I think its worth it.
Bill A
« Reply #2 on: 25 Aug 2013, 09:00 pm »
Thanks, KC.  I'll give the Nest another look.
Bill
