Virtue One.2 power supply compatibility--need help with ID
jim1274
I have a Virtue ONE.2 with original basic included 24V power supply that failed and am trying to identify best option for a replacement PS.
In searching the forum, I noted that several people have used the  Astron LS-10a power supply with good results.  This model does not seem to be as readily available as the  Astron VLS-10a power supply (http://www.dxengineering.com/parts/asr-vls-10m).  These appear to be basically the same PS but the VLS series is a variable voltage unit.  Would this work OK with the ONE.2??  They can be found used for about half the price of the  Audiophile 30v/130w Power Supply from Virtue.  Would the Astron VLS be an acceptable substitute for the 30v/130w unit?  Are there others besides the battery options that I should consider?
« Last Edit: 16 Aug 2013, 01:37 pm by jim1274 »
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
Re: Virtue One.2 power supply compatibility--need help with ID
« Reply #1 on: 21 Aug 2013, 12:42 am »
Probably the same supply.  You can check the output with a voltmeter and make sure it does not going above 31v.
Also, check out the Sinpro SPU130-109.  That's the unit we OEM and you may be able to find it in distribution - cheap!
You'll need to cut off the connector and graft on the 2.1/5.5mm job that's on the 24v supply.
The unit responds well to better power.  Enjoy!
jim1274
« Reply #2 on: 21 Aug 2013, 09:32 am »
Thanks for the suggestion, but already looked for the Sinpro and came up empty.  There was a used variable voltage Astron I found for 70 bucks--if still availabe it sounds like that will work from your comments.   If paying full price for a new Astron, I might as well just get Dodd battery kit from you for not that much more.
virtue
    • Virtue Audio
« Reply #3 on: 21 Aug 2013, 03:15 pm »
Reach out to Gary directly on the battery kit because I think we're out of them.
He seems to have taken his product line up-market which totally makes sense.  He has some scary, terrible medical bills to pay and frugal shoppers like us just can't help him that much.
