Room Resonance Remover Notch Filter
0 Members and 1 Guest are viewing this topic. Read 2243 times.
LonnieBedell
« on: 13 Aug 2013, 05:57 am »
The Room Resonance Remover(tm) from Lonnie Bedell Electronics is a new audio notch filter that uses subtractive equalization to cut in the 125-540hz range to counteract room resonances that degrade sound quality in Home Stereos.
At first glance professional sound reinforcement and home stereo may seem worlds apart, but they both suffer from the same room resonances that amplify certain frequencies as the walls vibrate sympathetically. This causes the sound system to feedback prematurely at those frequencies, as well as sounding "muddy" as the low mids are amplified by both sound system and the room itself.
While the immediate goal for a PA engineer may be to get more gain before feedback, by "ringing out the room" they also inadvertently gain the additional benefit of flattening out the frequency response of the listening environment by working with the room's natural characteristics instead of against them.
Home stereo and other consumers can benefit from the same subtractive equalization as well. Instead of boosting high frequencies, for example, they may find a cut in the the low mids they are amplifying might yield them all the high end they desire.
The Room Resonance Remover(tm) cuts up to 30db in the 125-540hz range on 2 separate channels. The RRR has variable settings for frequency, Q (filter width), and depth (amount of cut). Inputs & outputs are line level, and can be configured as RCA or 1/4" jacks. It is available in 9 Volt battery or AC powered versions. High performance 5532AP op amps are used throughout for low noise.
Russtafarian
  • Typical reaction to the music I play
Re: Room Resonance Remover Notch Filter
« Reply #1 on: 13 Aug 2013, 05:17 pm »
The price?
How many filters per channel?
Can the filter for each channel be adjusted independently?
Why not move the range to 300hz and below to better cover the transition zone of a typical residential room?
AJinFLA
  • Soundfield Audio Loudspeakers
    • Soundfield Audio
« Reply #2 on: 13 Aug 2013, 05:39 pm »
Hi Russ,
I think from the pic/description it's a single band parametric (width/depth variable) eq on each channel, variable between 125hz-540hz.
No clue on the price. :wink:
cheers,
AJ
mgalusha
« Reply #3 on: 13 Aug 2013, 05:55 pm »
Looks like $150 for the AC powered version.
http://www.roomresonanceremover.com/buyitnow.htm
LonnieBedell
« Reply #4 on: 14 Aug 2013, 02:41 am »
Yes on all questions. The frequency can be adjusted separately on each channel. It can be made with a different range fairly easily, 300hz down how far? 20hz?
Lonnie Bedell
