0 Members and 1 Guest are viewing this topic. Read 6933 times.
Or you could get some better speakers
Yeah - wave that red cape, Tyson, wave it..........At 1.7 money is there anything on God's green earth that's really better............
Define better? I just heard 1.7's for the first time, and I thought they where too forward.... at first I thought they where too thin, this was with the bass panel, then disconnected the bass panel, they I was surprised how well it did the bass..... They seem like they are revealing, not sure what is going on. But it sure doesn't sound "warm", that is for sure... cold is what I would call it.... Maybe tubes would have helped (this was with SS amps)...
"Better" to me would be more realistic / transparent and revealingThe 1.7's can get "analytical" compared to many typical box speakers, which is why many choose to add a tube or more somewhere in the signal chain to add a bit more "humanity" to the equation.
Not sure what you meant by "disconnect the bass panel" : this is not an easy user selectable option that I'm aware of. And even if you could, disconnect the bass / mid-range panel, I'm not sure anyone would want to listen to just the tweeter & super tweeter HF section......The 1.7's can get "analytical" compared to many typical box speakers, which is why many choose to add a tube or more somewhere in the signal chain to add a bit more "humanity" to the equation.
