0 Members and 1 Guest are viewing this topic. Read 6472 times.
Great topic, Steve. I have first hand experience with bundled wiring causing electrical problems so I can relate.Is there any chance you could provide some oscilloscope screen shots to demonstrate what you are talking about? We do have some members that steadfastly believe point-to-point wiring is the only way to wire an amp yet there are so few mfrs that do this in production. Personally I can't think of one right now. Anyone that can please share that mfrs name.
Very interesting guys....Here is what may be a dumb question but I'll ask it anyhow.Obviously the PCB is going to solve the consistant layouot and component placement issues of a point to point wired amp but what stops the above issues relating to "cross talk" or "transmission/reception" by wires in a point to point wired amp when using a circuiit board ?Are the signal paths positioned far enough apart that it isn't an issue with a PCB . I sem to recall seeing some pictures of boards where the paths are laid out pretty close to each other but I could be mistaken.just wondering if there is more going on than just consistant spacing of the signal pathways-jay
Some companies use traceless circuit boards to consistently place the parts in the same location, and then they hardwire the leads. This seems like a good compromise to me. At least there is more consistency in manufacturing this way, regardless of how it is layed out.I'm not sure if the audio band needs the same attention to layout as the Ku band, but its definitely worth considering.
Hi Steve,I have not posted here for a while, but a few glasses of red and, well...Interesting thread. I agree with some of your premises and arguments in principle... but not your conclusions/ solutions.
There are countless examples of shoddy P2P wiring. But, would it be honest to compare crap examples of P2P with the finest examples of PCBs... then claim PCBs as inherently superior?
I see some convincing arguments for not bundling cabling, but little to suggest - apart from repeatability - to support the use of PCBs over well-executed hard-wiring. I'd rather have a simple(ish) tube circuit well hard-wired and performing from very, very fine to excellent versus a (merely) fine sounding PCB. Put differently, I think hard-wiring has greater potential, and if well-executed - although still slightly variable - will outperform a well laid-out PCB. However, digital and other types of circuits are likely a different matter... I am not familiar with high-gain tube pre-amps that use lots of little tubes, so I have no idea what might be preferred for these.
There are methods that can maximise the benefits of both PCBs and P2P without incurring the disadvantages... but that is a separate discussion.
Steve, I notice you are an industry participant; do you sell products that utilise circuit boards?
Docere Steve,I think we are probably more in agreement than not. I also apologise for the pernickety tone of my post; it is counter-productive for me to post when in a particular fame of mind. I try to impose a limit of two posts per thread, so I be specific in this final post.
You have presented some opinions; some I share (especially the bundling point), others I don’t. I did not read any references to “facts” that clearly indicate the superiority of PCBs over hardwiring.
I saw conjecture that could be based on some understanding of electrical theory and physics and simple experiments. If you can point me to some peer-reviewed articles that that document experiments – with strong internal and external validity - comparing well implemented PCBs to hardwiring in a range of tube circuits, I will reconsider my position.
People, me included, confuse opinion with facts continually; it is our way. Opinions are important, but, we should not accept opinion, no matter how expert, as fact. Perhaps I have put too much emphasis on this point – it is what first irked me about the thread; best to pull my head in and move on…
Although not mentioned specifically, I had three things in mind when posting my comment about methods having the benefits of PCB and hard-wiring 1) an amp I am currently planning the layout for, 2) an article in SP about using Teflon sheet for mounting components, and 3) an article about AN build methods from many years ago.
My point about you being an industry participant was in relation to competing interests: potentially promoting your products on a public – not manufacturer – forum. I was not suggesting that you were not walking the talk, which might be what you thought? Anyhow, the information you have shared will be helpful for many.
QuietEarth subsequently posted some specific details of a similar approach used by manufacturers. I agree with your comments in response to Quiet’s post.
My relatively simple build will use 2mm Teflon sheet, finely drilled to mount components and connect component-to-component where appropriate or using good quality wire where not. I like this approach for the technical reasons discussed, but also for its simple practicality: easier to work on; allows concurrent build of different parts of the amp; promotes tidiness and logical layout; and is very suitable to optimising layout.
Gents,This has been a most interesting thread so far and is an important subject to electronics in general but especially in audio electronics. Things have been discussed in a most civil manner and I know you will keep it that way.To Docere's credit he made the simple point that we all make mistakes in interpretation of facts and opinions.To Steve's credit he has presented his information without any callouts for his company or equipment. It would be nice to see some hard evidence such as links to published articles and/or comparative images of oscilloscope readings of each design compromise.Anyone engaging in this discussion is also subject to his or her beliefs. Lets try to remember that and allow some flexibility where it's needed.Thanks and carry on.
