0 Members and 1 Guest are viewing this topic. Read 8090 times.
Thanks for the review. Glad you're a satisfied customer and on your audio way.Just a few suggestions/questions:Getting them up above the desk should help improve imaging.Positioning them so that the driver is aimed at ear height should also provide extra high frequency response.Please clarify your opinion of the Dayton sub. (I've been curious how these very inexpensive subs actually sound and so many folks looking in their price range just want boom-boom bass.)
If these speakers have a downfall, it is the low end. I tried to run them without a sub, and if I only listened to jazz, it would have been fine. However, it sounds too light with other genres. Others have stated that it is my sub-par amp. However, I also hooked it up to my Yamaha 663 just to find out. This receiver does about 95 watts per channel. While the bass did get better, I would still want a sub for any genre other than jazz.
Excellent advice JLM! And +1 for aiming at your ear position, especially if you are listening "Near Field". (And by the way single driver speakers such as Omega and Hoyt-Bedford are the "bomb" for Near Field listening!)Others have mentioned in another thread about the amp you are using should eventually be upgraded when your budget allows and since you have speakers with good efficiency - I would look into tube amps in the $1000 or below range.In the mean time, take a look at the Pioneer SW-8MK2 Subwoofer that was designed by Andrew Jones. This subwoofer was recommended to me by a forum member, the price is right ... the price is so right, you can add 2 for better results and still not break the bank (2 hould give you better results than sub with a 10" driver) and I've read some good things about it, or if you want a 12" driver then look towards Hsu Research's VTF-2 MK4.Also IMO, I would wait until you have the other pieces of audio gear (and put more of your budget into the other gear) before you start messing with speaker and interconnect cabling. While I think good cables are "important", I am one of those that believe the gear is "more important" and the bulk of one's budget should be spent there rather than cables and then (after you've got the basic gear in your system) you should start experimenting with different cables to get the sound just right.
Believe it or not, a small single ended (SE) tube amp may give more bass than your 95 watt receiver, and the reason is the low damping factor of the SE amp allows the speaker driver greater excursion allowing for more bass, whereas your receiver with it's likely high damping factor allows less excursion, hence less bass. Most people think having more power means having more bass, and very often this is just not true. Omega and Hoyt-Bedford speakers are generally friendly to all amp types, but they clearly favour tubes. If you have a hundred hours on the speakers and upline gear that synergizes with them, you should have very satisfying bass without a sub, especially in a nearfield setup. If anything, I found the Super 3T to have almost too much bass on the desktop, and that was with a 2 watt Decware amp. Damping factor is everything with the RS5 driver which has a looser surround than the old HempCone it replaces. Not having a DAC can also have a big impact on the bottom end. Here is another thought: In this day 99 % of stereo owners are used to the bass produced by multi driver speakers which for the most part is overpowering and often bloated and unnatural. They then buy a pair of good single driver speakers like Omegas or Hoyt-Bedfords with their very natural "live" bass and think they are anemic on the bottom end, when in reality they need to re-tune their ears to how live music really sounds, and a good single driver speaker gets as close as anything I have heard.
As far as amps, the TBI millenia that Ozark Tom has going on tour would be a good choice. I auditioned it and it's probably going to be better than most lower end tube amps. It wasn't better than my DIY pre and amp, but I have $2k just in parts invested. For $500 the TBI comes uncomfortably close to very expensive amplifiers. Also, I have the Super 3 XRS and still use a sub, a decent sealed sub will match up well with the Omegas. Louis has more subs on the way, I'd talk to him about getting an Omega sub, I know that's what I'm going to do as my next upgrade. I have a nice Adire 10" sealed sub, but want a pair of 12" subs. As far as cables, the stuff that comes in the box with cheap components are worth replacing immediately. I wouldn't spend much but there is a huge difference between CHEAP cables and decent inexpensive cables. Once you get equipment you plan on keeping for a long time, then look into better cabling.
That TBI millenia is quite out of my price range. I have been considering NAD 325's and such, and even used on a-gon for around 250-300 is quite the stretch. The musical paradise is about $400 shipped and that is pretty much my absolute max and would also cure my desire for a HP amp AND a tube amp.For sub, I was thinking the SVS SB-12 NSD for $650 shipped. It's a sealed 12" and was recommended to me directly from Ed Mullen at SVS.As far as cables, I don't plan on spending more than $75 total. More like $30 would be great.
The TBI is only $100 more than the musical paradise. You could look for one to pop up used. IMO, the amp is very, very important. I'd prioritize the amp over spending $650 on a sub. I'd also prioritize a decent DAC over the sub. A good sub is nice, but you can find one used for much less than $650. My Adire sub retailed for $1k and I got it for $300 on ebay. If you don't have a decent source and amp you won't be doing those speakers justice. Garbage in, garbage out and there's no speaker in the world that will make up for a poor source and amp. I've owned NAD amps in the past and I don't feel it's going to be a great match for the Omegas. There is a tour for the TBI amp going on, you should join in and check it out. I'm 99% sure it's going to crush both the NAD and musical paradise by a very large margin. And don't underestimate how much really cheap cables degrade the sound. As I said, if you diy your own cables you can get a decent IC and SC for about $50 total. It will make a huge difference.
Not to diss Dave's own cables, but being an audio old fart I have a hard time spending serious money on cabling.
I've looked at Dave's cables and I was really pleased to see that they are super-affordable, especially compared to "serious money" cables
FYI...I am using a TBI Millenia with Omega super 6 Alnicos and enjoiy it a lot. I don't feel I need a sub for any type of music.
