0 Members and 1 Guest are viewing this topic. Read 8344 times.
Suggested reading.... http://www.vinylengine.com/turntable_forum/viewtopic.php?f=46&t=53152Interestingly the complex behaviour of the shibata tip is discussed - the contact patch of the shibata is not strictly linear, it has a slight curve....I have never seen a decent comprehensible summary of shibata behaviour with SRA/VTA...I am uncertain whether that curve is an advantage or an achilles heel, it may be the main reason why designers went down the path of more sophisticated and more linear profiles...
+1 Jim. Read the reviews, the info, etc., and then try it for yourself and make up your own mind. Don't take it too seriously. Enjoy! Neo,I liked your comment about parallax error, but I didn't understand why you think Roy Gandy is deaf. He has probably done more good for the vinyl induststry than many others. Did I miss something? Maybe it's an inside joke.
It's well documented that Gandy thinks arm height makes little or no difference, hence the shims.
