Finished product clarinet
0 Members and 1 Guest are viewing this topic. Read 2612 times.
ricardojoa
« on: 14 Jul 2013, 01:09 pm »
Can the clarinet be ordered in a finished product. I dont see on the order page so i guess not. But im not technically inclined to built my own tube preamp.
poty
Re: Finished product clarinet
« Reply #1 on: 14 Jul 2013, 05:32 pm »
I think many DIYers can build one for you! :) JH designs are very appealing to builders!
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 14 Jul 2013, 06:45 pm »
Buy this and be done. http://www.audiocircle.com/index.php?topic=115482.msg1207203#msg1207203
galyons
« Reply #3 on: 14 Jul 2013, 07:37 pm »
Just to clarify, the current board available from Jim is a Cornet2.  Mike's, (mgalusha), is the original Cornet.  That being said, Mike's Cornet is an absolute steal at the price.  With the factory based mods done to the board and the upgraded components, it will likely not be sonically much different than the Cornet2, and MUCH better than a stock build Cornet2, IMO.
If you are seriously looking for a Cornet already built, you should grab this one NOW!
Geary
« Last Edit: 16 Jul 2013, 05:05 am by galyons »
hagtech
« Reply #4 on: 16 Jul 2013, 03:28 am »
The CLARINET boards are still on version 1 - but is same size and shape as the CORNET2 - both designed to fit perfectly into the Lansing chassis.
No, presently I do not offer CLARINETs in assembled form.
jh
poty
« Reply #5 on: 16 Jul 2013, 06:14 am »
The question was about Clarinet (line stage), not Cornet (phono amplifier). :)
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #6 on: 16 Jul 2013, 11:27 am »
Oh... :scratch: and I thought the question was about a woodwind instrument and the proposed answer was about a brass instrument.
Best  :wink:
Anand.
limits
« Reply #7 on: 16 Jul 2013, 02:47 pm »
Hi Ricardo--I have one that has been sitting in a closet for 3 or so years (waaay too much stuff). It is nice, but does have a bit of hum with the couple of sets of speakers I used it with. I am the second owner of this Clarinet, and I believe I paid the original owner/builder $400.00 for it, but would be willing to let it go for a lot less than that, as I don't plan on using it anytime soon. It uses pretty much stock parts, but has Sonicap caps (not the platinums). PM me if interested.
