0 Members and 1 Guest are viewing this topic. Read 14540 times.
If you mean me (Bob, ctviggen),..........
$50 for a light bulb!?!!?! How about something like >> THIS <<
Ohhhhh I missed the fact it was a four pack. My bad.
I also wonder about the quality of Feit bulbs? Without any real reason, I consider them to be lower quality stuff.
So you thought I would pay $50 for a light bulb?
I've had some Feit CFLs that really cooked themselves turning the ballast housing yellow (base down upright installation in open air lamp) that seemed to fail sooner compared to some other CFL brands that lasted much longer, so I kind of have that impression too.Steve
Well....."Yes". I did. I don't know you, so therefore, I didn't know your level of "dumbassity".As it turns out, I showed my level instead. On a slightly related note:I heard a story where a firefighter said that CFL's in "down" situations are a fire hazard. (glass down, ballast up) He'd seen quite a few residential fires where CFL's in that configuration were the cause.Take that with a grain of salt.
