5Y3GT Same As 5R4GY?
david62
« on: 12 Jul 2013, 08:26 pm »
Will a 5R4GY rectifier work in the Clarinet?
galyons
Re: 5Y3GT Same As 5R4GY?
« Reply #1 on: 12 Jul 2013, 09:12 pm »
Yes, same pins, same heater current, similar voltage drop...the big differences are  the max current, max AC voltage per plate and PIV.  Generally the 5Y3GT is a preamp/ small amp rectifier. The 5R4GY for current hungry amps.
What are you looking to accomplish?
Geary
david62
« Reply #2 on: 12 Jul 2013, 09:32 pm »
I have a old Coke bottle 5R4GY and I thought that I would try it mainly because it looks cool.I'm not sure that it would have a sonic impact.
hagtech
« Reply #3 on: 14 Jul 2013, 03:30 am »
You can use either tube.  A real 5Y3 is directly heated, and will power up much quicker.  The 5AR4 (GZ34) types have a built in delay mechanism being indirectly heated.  It is difficult to predict the sonic impacts, but changes will definitely be heard.
jh
david62
« Reply #4 on: 21 Jul 2013, 01:03 am »
I tried the 5R4 in the Clarinet.I would say that it sounded more lively,somewhat less laid back with good solid bass.I had been using a old RCA Coke bottle 5Y3,but I think I will leave the 5R4 in for now.
Dave
