Magnepan and Bryston!
0 Members and 1 Guest are viewing this topic. Read 20556 times.
HsvHeelFan
Re: Magnepan and Bryston!
« Reply #20 on: 7 Oct 2013, 07:04 pm »
I have KEF's due to the Wife Acceptance Factor.   She liked the narrow, tall footprint.
I'm okay with that because they sound good.
When I need to upgrade, I'm going with the Bryston A1 or Model T's.  It'll depend upon what my budget is.
HsvHeelFan
Vipers
« Reply #21 on: 10 Oct 2013, 12:40 pm »
Did you have a good turnout for your event?
Hi Steve,
Yes, considering that Magnepan are not that well known over in the UK I was really pleased with the turnout, we had a steady flow throughout the day, the main thing was that everyone was extremely impressed, many of them new to Maggies :)
klao
« Reply #22 on: 28 Oct 2013, 05:11 pm »
Just got them last Saturday in my (almost finished) new room: Bryston 28B-SST/2 Pro + Maggie 20.7.  Have to run them in a bit more, but so far, a pretty awesome combo.
We have yet to hear from James of his impressions, since he's got them in his room many many months already.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #23 on: 28 Oct 2013, 05:25 pm »
Great looking room - what do you have in the front corners?
james
klao
« Reply #24 on: 28 Oct 2013, 05:37 pm »
Thanks, James.
At the four corners of the room are LF/bass traps similar to the RPG's.  Mine are made by the contractor from the equivalent of Owen Corning 703 fiberglass and wooden frames per design of Richard Bird - Rives Audio.  The three wooden structures next to the bass traps serve as front wall diffusors.
Rod_S
« Reply #25 on: 29 Oct 2013, 11:17 am »
Very nice! What's the amp in the middle powering?
« Reply #26 on: 29 Oct 2013, 11:23 am »
Thanks, James.
Looks neat - what material did they use for the bass taps?  Do you know what the NRC ratings are?
james
klao
« Reply #27 on: 29 Oct 2013, 03:32 pm »
Basically, plywood frames and the 2" semi-rigid 703 fiberglass on the two sides against the wall and 1" where it's covered with cloth.
http://commercial.owenscorning.com/assets/0/321/333/f28dc02d-7b1f-4678-b20d-6e6ae855be0c.pdf
So There
  • Brystonized
« Reply #28 on: 29 Oct 2013, 06:19 pm »
Beautiful system and room, Klao! It's clear you've given both a great deal of thought.
Best wishes for many happy hours of listening.
Rich
_______________
Whiney Napa Valley
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
klao
« Reply #29 on: 29 Oct 2013, 06:45 pm »
Rich
_______________
Whiney Napa Valley
Thank you, guys.
The amp in the middle is supposed to power up the Maggie center speakers of which I'm running out of money to buy them now.  :)
emailtim
« Reply #30 on: 14 Dec 2013, 06:31 am »
How do the 20.7's, bass traps and diffusers sound now that you have had some time on the 20.7's ???
TIA
P.S.
Love your venue and setup.
klao
« Reply #31 on: 27 Dec 2013, 07:25 pm »
TIA
P.S.
Thanks, Tim.  I've been adjusting the speakers bit by bit all these while.  The performance of the 20.7's, the Bryston gear, the traps, the diffusors, and the room are very much to my satisfaction.
It appears that Richard Bird and the team at Rives Audio really know what they're designing and advising.  Will have to do some sound measurement and send back the results to him later when all setup would be done.  You can follow the progress in my gallery.
