Tube microphonics anyone?
0 Members and 1 Guest are viewing this topic. Read 4256 times.
JerryM
  • Where's The Bar?
Re: Tube microphonics anyone?
« Reply #20 on: 13 Jul 2013, 07:13 pm »
There are some good line-noise troubleshooting tips located here.
Best of luck,
Jerry
doctorcilantro
« Reply #21 on: 26 Oct 2013, 04:15 pm »
What happened with this problem? Did it get resolved?
rbwalt
« Reply #22 on: 27 Oct 2013, 03:05 pm »
i would go with what Jake has stated. sounds like a bad driver tube. it could also be lose in its socket. i have had that happen to me a few times. if you can get at the driver tubes then take them out and put them back in. might want to try some deoxit on the pins. i never had a power tube make the sound you are hearing. not going to be your wire or PC. you would get hum but not the sound you are hearing. so start with the driver tubes.
good luck.
