0 Members and 1 Guest are viewing this topic. Read 21876 times.
Nice graphs and I can see your reasoning based on this limited information but let’s look at the bigger picture with some real FS measurements and a quick calculation shall we:Distance between tweeter and FR driver: 10 cmReasonable listening distance for fantastic stereo image: 300 cmTherefore using Pythagoras distance differential between tweeter/FR and listener is: 0.166 cmTake a frequency of 10KHz when the tweeter is fully implementedThis gives a wavelength of 3.43cmNow frequency cancellation would occur at ½ wavelength differential, that’s 1.72 cmSo we are 1/10th of half a wavelength differential at 3M, and that’s for the very worst case scenario wavelength shift (moving your head up/down until you receive the largest dip).Please correct me if I have made an error in these calculations (I only had 5 mins) but it is no wonder you can’t hear any hint of combing at 3M, given the real perspective of in a non-perfect room conditions of 2 line sources using non perfect drivers. If you can hear any such effect you qualify for the Golden Ear award! Kevin
Now which speaker will have a smooth power response?
At the risk of being dragged into the bottomless hole... Any which measure that way. You didn't provide that though.
I have a question for Jim Griffin about the power response. Toole says that flat on-axis and smoothly-varying power response are preferred. So, by that, any "comb filtering" at any particular off-axis point is irrelevant, is it not? What counts is the average over some vertical/horizontal window.So, considering just the question of the two Jordans running full-range for the moment, why is there a problem exactly?
If you want to call the "power response" a summation of on and off axis response (independent of the room)...
Hi John,Yes, Toole does say that. Yes, there will be averaging, the total sound power at the LP will consist of the direct field and reflected fields (plus modal interaction, etc.). As arranged, the Jordans will be ok on "design" axis and directly horizontal off axis. But anywhere else will be as below, or worse (I'm sure you've used Edge before, fairly easy to sim):
Hi AJ. Thanks but aren't you avoiding the question?
OK, the question I had is, given that the on-axis response of two full-range point sources is flat, what does the power response look like.
I thought it was less than +/- 180.
Regardless, any plots to share? Just to couneract the thousand meamingless ones so far.
? The sharp drop above 5k anywhere not directly on design or horz off design axis, will most certainly have consequences to the sound power.
My position is that some of what Danny says is sensible but its not something I worry about too much.
It certainly makes sense to have an even room response but I don't think room response is necessarily given by a few off-axis readings at different heights.
You can measure a very flat room response from a completely omnidirectional speaker, indeed the flattest, but what are you actually listening to - it's garbage, very room dependent, little imaging and certainly not something that was in the recording. You are just hearing many virtual copies of the loudspeaker appearing from different points all around you. It's not really a good design consideration to achieve a flat response in-room if you lose all the acoustic detail in the process. This is where the industry has actually gone so terribly wrong. The beauty of Ted Jordan's designs is that they appreciate a good degree of directionality is important in detail resolution, minimising any room response and maximising true stereo imaging (not ghost images). Having said that is is of some importance that the room does sound right and this is a small property of the speaker but a large property of the room. Common sense really!
