Looking for a temporary low cost DAC
0 Members and 1 Guest are viewing this topic. Read 7507 times.
paul79
Re: Looking for a temporary low cost DAC
« Reply #20 on: 30 Jun 2013, 05:54 pm »
http://www.audiocircle.com/index.php?topic=117865.0 From our very own Steve Nugent of Empirical audio. I can't imagine you doing any better than this DAC for $500...
JEaton
« Reply #21 on: 30 Jun 2013, 06:13 pm »
Unless the Touch has been modded, USB only DAC's would not work.
Am I missing something?
It only requires a software applet on the Touch - Enhanced Digital Output (EDO):
http://forums.slimdevices.com/showthread.php?94512
jackman
« Reply #22 on: 30 Jun 2013, 08:33 pm »
Easy.
ODAC.  http://www.jdslabs.com/item.php?fetchitem=46
In stock unmodded form?  Just wondering because I've heard mixed comments regarding this dac and NWAVGUY is MIA.
I'm pulling for these guys for so many reasons; compelling approach to development, low cost and the US manufacturer is in Illinois.  Just wondering how it sounds withou any external ps or mods. Thanks
jtwrace
    • TIPP YouTube Channel
« Reply #23 on: 30 Jun 2013, 11:47 pm »
Stock.
NWA guy doesn't build them anyway.  He just designed it so JDS and the other guy in Canada are the two go to guys for USA & Canada sales.  I own one and it's awesome; not only objectively but subjectively.
jackman
« Reply #24 on: 1 Jul 2013, 01:14 am »
Stock.
Thank you!  I ordered one on Friday and just read a couple not so hot reviews.  I respect your opinion and look forward to getting it!
Cheers
Jack
jtwrace
« Reply #25 on: 1 Jul 2013, 01:17 am »
Cheers
Jack
Well, it's honest (the ODAC), it is what it is.   :dunno:  I would've sent you mine to try.
JCarney
« Reply #26 on: 1 Jul 2013, 01:25 am »
I have a Parasound Z-DAC that I really like. I would say it punches way out of its weight class. It can be had for $475.
JCarney
http://www.amazon.com/Parasound-Digital-Analog-Converter-Black/dp/B00ANTVS90
jackman
« Reply #27 on: 1 Jul 2013, 12:49 pm »
Thank you. They are in Illinois, close enough so that shipping was cheap. The whole thing was cheap for that matter.  I was going to pick up the new $99 Schiit DAC but this one caught my eye.  Will report back!
Cheers
Jack
jtwrace
« Reply #28 on: 1 Jul 2013, 02:28 pm »
Cheers
Jack
Look forward to your thoughts.   :thumb:
jackman
« Reply #29 on: 1 Jul 2013, 03:41 pm »
Thanks, I appreciate your recommendation.  They JDS Labs guys are very cool.  I switched from 3mm jack to RCAs and they responded immediately confirming the change.  I may get the 02 headphone amp as well.
mca
« Reply #30 on: 20 Aug 2013, 01:43 am »
OK, it's been a while since I first posted this thread. I have tried the following DAC's out and have not been impressed so far. Bifrost Uber, ifi iDAC, Audioquest Dragonfly, Peachtree, Dac-It. They all sounded OK, but not what I think is up to the standards of the rest of my system. I have been saving since my original post and am ready to step up to the 1-2k range. From what I have read, a used Bryston DAC-1 may do the trick. If anyone has any other suggestions, please feel free to post them  :D
WGH
« Reply #31 on: 20 Aug 2013, 02:17 am »
New Fet Valve Hybrid DAC $2495 at the AVA site. In two shoot-outs we found the AVA DAC sounds just as good as the $4000 PS Audio PerfectWave MKII.
Yup, over your budget but consider the Vision Hybrid at $1999. I heard one in my system and it is still very nice. 30 day money back trial too.
Wayne
DaveC113
  • ZenWaveAudio.com
« Reply #32 on: 20 Aug 2013, 02:18 am »
A little pricier but check out the Auralic Vega, it is awesome. I heard it at mgalusha's place along with a Teac, my Bifrost Uber and HiFace and it is in another league entirely. I like my Bifrost but it sounds like crap in direct comparison. The Teac was actually the worst of the bunch... slow, bloated and artificially smooth. It was voiced to be as non-offensive as possible imo.
Mike recommended the Yulong DA8 at a lower price point and said it's much closer to the Auralic than the Teac, which were the two on hand at the time. At $1200 it seems like a good value.
adydula
« Reply #33 on: 22 Aug 2013, 04:51 pm »
JDS has the O2 dropped down complete for $129......a really great price for this Gem...
I finally sold all my other head amps etc and settled on several of these.
Awesome..
Alex
geowak
« Reply #34 on: 22 Aug 2013, 05:14 pm »
If the Auralic Vega ran over the Bifrost Uber as two here have compared, I would get one. I mean the Bifrost has been getting rave reviews as a budget DAC, and it was designed bu two veterans in the digital world. So if the Auralic is in a different league by direct comparison it must be very good.
jackman
« Reply #35 on: 22 Aug 2013, 06:20 pm »
Hi Guys,
I forgot about this thread!  Just wanted to thank JTWrace for the ODAC recommendation.  I've been messing around with this DAC for a couple months and I like it a lot.  I have the JDS Lab version with RCA's and it sounds very good, especially with 24/96 material and a PC with JRiver.  The setup is very inexpensive (HDD, old laptop, JRiver, and ODAC) and the iphone remote JRemote works great.  For very little money, it sounds great.
I have not tested any high-end DSD Dac's and look forward to testing the Sonore, Chord, etc.  For now, as a temporary stop-gap, the ODAC works and sounds great.  It's also very easy to set up.
Good luck
Jack
Daedalus Audio
« Reply #36 on: 22 Aug 2013, 07:25 pm »
check out the Parasound Z-DAC.  especially good with the balanced outputs.  it's what I use in the shop when I don't want to burn tube life in the tube dac's
http://www.parasound.com/ParasoundZ/zdac.php
