nCore DIY dual xlr inputs?
0 Members and 1 Guest are viewing this topic. Read 1948 times.
spreadspectrum
« on: 22 Jun 2013, 03:38 pm »
I was hoping to get some advice on a possible Hypex nCore 400 project.
I have been largely holding out on building these because of a somewhat peculiar need of mine - that is, I require two inputs on the amplifier.  The reason for this is not necessarily important.  What I am interested in is whether or not it is possible to wire a second xlr input without any technical risks or issues.  The two sources would never be on at the same time.
Any ideas?
Thanks.
Ryan
cab
Re: nCore DIY dual xlr inputs?
« Reply #1 on: 22 Jun 2013, 03:54 pm »
You could put as many additional inputs as you wish, as long as you don't try inputting signal into more than one set at a time. For safety sake, you could wire in a switch to change between them so that never happens.
mrhyfy
« Reply #2 on: 22 Jun 2013, 04:37 pm »
Why not throw in an input selector and an attenuator? Makes a nice integrated amp! :D
