Which arm will work better?
0 Members and 1 Guest are viewing this topic. Read 1333 times.
simoon
« on: 13 Jun 2013, 04:16 pm »
Which arm would you chose for a Systemdek XII, and why? I am going to give the table to my cousin.
A Linn Basik lvx -
Or a Grace G-840F -
neobop
  • BIRD LIVES
Re: Which arm will work better?
« Reply #1 on: 14 Jun 2013, 10:48 pm »
I believe the Basik or Basik Plus which is very similar is the original arm on the Systemdek.  It might be easier to tune the suspension with the Linn arm.
On the other hand, I think the Grace might be a little better arm, especially with MC carts.  I don't know the gross weights of either.  They might be similar.
Tuning the suspension so it bounces straight up and down, is essential for optimum performance
neo
