Re-Glueing a Phase Plug on 626R
0 Members and 1 Guest are viewing this topic. Read 1095 times.
santakrooz
« on: 12 Jun 2013, 03:26 am »
Hi, The Phase plug came loose on one of my 626R woofers. Looking for any advice on re-gluing in. ie technique and recommendation on type of glue to use.
Thanks in advance
Michael
Brax
Re: Re-Glueing a Phase Plug on 626R
« Reply #1 on: 12 Jun 2013, 08:24 pm »
I had one come loose and I used hot glue to reinstall it. I used hot glue so it would set fast since I had no real way of clamping it ( I never removed the speaker from the cabinet) . I also cleaned all the old adhesive off the plug before putting it back in. Just be careful to not use too much.
santakrooz
« Reply #2 on: 23 Jul 2013, 02:41 am »
Thx. I used silicon adhesive and it worked fine. Cleaned off the old as you pointed out. Working great.
-sk
