New Clarinet...Help
Quicksilverproac
Re: New Clarinet...Help
« Reply #60 on: 23 Jun 2013, 04:23 pm »
I did get my amps going ...so everything is working ...except the Clarinet.
poty
« Reply #61 on: 24 Jun 2013, 06:57 am »
Have you made anything to check the Clarinet?
What was wrong with your power amp?
Quicksilverproac
« Reply #62 on: 25 Jun 2013, 02:08 am »
Well, everything is working with the exception of the rca outputs of the Benchmark DAC. It seems the power amps and the Clarinet were ok...the DAC rca outputs were not working . I think thats what blew in the first place. I used the xlr's from the DAC and the power amps worked. I hooked up my laptop to the Clarinet ...it work. I am very sorry for all the problems. I have been using the Clarinet on different amps and speakers...it sounds good , but it seems to bright. This may be the Vishays'...it sounded much different than the Cornet through my other preamp. Thank you very much. Allan
poty
« Reply #63 on: 25 Jun 2013, 07:07 am »
Allan, Don't understand - your Clarinet works or not? :)
Quicksilverproac
« Reply #64 on: 25 Jun 2013, 01:22 pm »
It works....
