Pretty Cornet 2
0 Members and 1 Guest are viewing this topic. Read 2543 times.
milosz
Pretty Cornet 2
« on: 3 Jun 2013, 09:13 am »
poseidonsvoice
    • 2 channel/7 channel setup
Re: Pretty Cornet 2
« Reply #1 on: 3 Jun 2013, 01:11 pm »
Yes! BIG PICTURES. Very pretty.
Best,
Anand.
milosz
Re: Pretty Cornet 2
« Reply #2 on: 3 Jun 2013, 07:54 pm »
Hard to see the details and the woodgrain in smaller photos.
el34
Re: Pretty Cornet 2
« Reply #3 on: 5 Jun 2013, 03:07 pm »
Nice!  Are those shields grounded to the chassis?
milosz
Re: Pretty Cornet 2
« Reply #4 on: 5 Jun 2013, 05:39 pm »
Yes the shields are anodized aluminum, where they lock the base is sanded to bare metal, the screw that holds the tube socket and shield base is grounded.
milosz
Re: Pretty Cornet 2
« Reply #5 on: 5 Jun 2013, 05:55 pm »
Some circuit differences-  Cardas teflon output coupling cap, other capacitors in the audio circuit are all Russian FT3  series caps; NOS tubes -  Raytheon 12AX7's and 6SN7, Philips rectifier.
Due to the large size of the Teflon caps, I had to build a separate set of turret boards to mount them
It sounds as good as it looks, maybe better  8)
