lcrim - Vinnie is definately the guy of Toshiba 3950/60 "fame", and also plays over at Head-Fi. Wayne at Bolder is the person that I chose to mod my Teac, but I do know that VinnieR also offers a set of mods - perhaps you can email or PM him for the details.
Larry you are right on the money that the PS seems to be the weak point here, and that is likely why a large portion of the mods that Wayne did to my amp centered around that area - better caps, shorter signal path, improved connectors, and the opportunity to play with power cords, all should add up to some decent improvements. Now, for the ultimate, battery power could prove really good, but I think that since the rails in the Teac operate at some elevated voltage, it would take a bank of batteries, not that cute little 3a that is in use with the Clari-T amp...
ludavico - yes, the Teac will accept banana plugs, I use them at present, BUT not the dual kind, just the single kind. By dual, I mean the single unit, with dual banana posts on it - the spacing is wrong for those, but you can use single banana plugs no problem.
