0 Members and 1 Guest are viewing this topic. Read 64808 times.
The german magazine stereoplay has some measurements of ATC 100's. I gave a link above.
Pete,The plot you show of the two way shows extremely good dispersion. I agree with everything you say. ATC are not on another superior level but ATC designs fulfill a niche market very well. The Tang Band 3 inch is an excellent driver but I doubt it can play as loud cleanly as ATC's Super 3inch dome (nor should one expect that given its modest price). ATC excel at clean sound at higher SPL a niche that studios like.
The measurements are absolutely excellent with distortion being more than 50 db down through the mid range at 100 db SPL. The speaker is actually rated at 115 db SPL continuous. The data does not show where the speaker really shines (at extremely high SPL's). The other review I linked to specifically states "A single ATC 300 cabinet will deliver an astonishing 121 dB SPL at less than .3% THD (with an additional 10 dB of headroom available!), an important consideration for loud pop music monitoring."I don't recall saying this was a "world beater". I stand by my statements that ATC characteristics are defined by critically damped bass, wide even dispersion across the mid range, and the ability to play significantly louder (while maintaining low levels of distortion and low compression) when compared to other speakers. These characteristics fulfill a highly desired niche in pro studio applications but they certainly do not make ATC a "world beater".The ATC design has not changed much over 30 years (incremental improvements in Amp Packs, tweeters, SL drivers etc). It would be very odd indeed if audio professionals continue to buy them considering their measurements are "nothing to write mother about", as you claim. The fact is that measurements do not really tell you everything - especially useless in this case as speakers are never tested at the live concert sound levels that large ATC's are capable of. The user list I gave in a previous post is probably a more useful indication to readers of this thread.
The measurements are absolutely excellent with distortion being more than 50 db down through the mid range at 100 db SPL (not sure if this was at 2 meters or 1 meter). The speaker is actually rated at 115 db SPL continuous at 1 meter. The data does not show where the speaker really shines (at extremely high SPL's). The other review I linked to specifically states "A single ATC 300 cabinet will deliver an astonishing 121 dB SPL at less than .3% THD (with an additional 10 dB of headroom available!), an important consideration for loud pop music monitoring."I don't recall saying this was a "world beater". I stand by my statements that ATC characteristics are defined by critically damped bass, wide even dispersion across the mid range, and the ability to play significantly louder (while maintaining low levels of distortion and low compression) when compared to other speakers. These characteristics fulfill a highly desired niche in pro studio applications but they certainly do not make ATC a "world beater".The ATC design has not changed much over 30 years (incremental improvements in Amp Packs, tweeters, SL drivers etc). It would be very odd indeed if audio professionals continue to buy them considering their measurements are "nothing to write mother about", as you claim. The fact is that measurements do not really tell you everything - especially useless in this case as speakers are never tested at the live concert sound levels that large ATC's are capable of. The user list I gave in a previous post is probably a more useful indication to readers of this thread.
These ATC speakers, particularly the SCM100A are simply the best speakers that I have heard for the money. They can produce dynamics like no other speaker in its price range and sound as good at crazy spl levels. I have yet to hear any distortion and compression from them and I have owned speakers costing twice as much from TAD etc There is no better monitor or Hi-end speaker period.
But all that really matters is does the owner like what he hears. And if the owner is a happy camper, what more needs to be said.
Stuart, When I listened to their whole product line this was their best sounding model in the line. However, I did get the feeling that the rest of the product line using passive networks might have been being held back considerably with budget level crossover parts. And the passive models were certainly being held back by the electronics used to demo them in the store that I auditioned them in. Upgrade the passive models with some decent parts and put them on better gear and some of those models my have really beaten up the powered model. I like the line and think of them as being very good (especially the drivers), but find them a long way from being able to use them in a statement like that. As a designer I had a hard time understanding why they designed a speaker with so much surface reflection from the front baffle. And as a listener I had a hard time getting past that. That element alone is not at all good for imaging and sound stage.
AJ,You asked for data and then you say anything can be made to look good.It is clear to me you know a lot about ATC such that you are convinced they are at worst a bad design or at best nothing special.Hopefully you have dissuaded anyone from auditioning ATC.Since nothing I say you can agree with except that ATC is an old design and things have moved on since then, I feel I have exhausted this topic.For the sake of civility and in deference to all the expertise here at Audio Circle, I'll refrain from commenting ever again.
As long as the OP is happy wih his choice, who cares what others think.
Hi Danny,Hope you are well my good friend?You are absolutely correct. I have heard the passive versions of the same monitors with a seriously upgraded crossover and using the Scan BE tweeter fed with some really powerful valve mono blocks and the Audio Research Ref 5 pre and they beat the actives hands down. We can debate all we like about various speakers being better than the next and I see that some people are getting quite excited about this! There is something very special about the sound of the ATC SCM100 and that beautiful mid driver with the right setup!!!!!!!!!!
I sincerely hope that anyone interested in a product audition it themselves, rather than relying on various fans, reviews, hype, street rep, celebrity endorsements, etc.Especially loudspeakers! Yes, that includes ATC.
Found some data regarding measurements and spl levels:http://www.diyaudio.com/forums/multi-way/87123-atc-sm75-150s-dome-mid-measurement-data.htmlhttp://mixonline.com/mag/audio_highend_studio_monitor/http://studio-hifi.com/images/All%20About%20ATC.pdf Looks like Shadrone was closer to the truth than .......
