Clarinet Volume Pot
Quicksilverproac
Clarinet Volume Pot
« on: 31 May 2013, 12:24 pm »
 I am building a clarinet....I have have been unable to get the volume pot ..Digikey P2T3503. Is there a direct replacement, Also.. will the Goldpoint, Dact,or Khozmo fit. Thanks, Allan
hagtech
Re: Clarinet Volume Pot
« Reply #1 on: 2 Jun 2013, 12:03 am »
P2Y7503-ND is the closest I can find.  It has a different bushing.  Electrically it will work, but the hole in chassis may need to change.
jh
Quicksilverproac
« Reply #2 on: 3 Jun 2013, 11:09 pm »
Thank You
poty
« Reply #3 on: 4 Jun 2013, 06:35 am »
If the size of the case is enough you can use any pot you like (remembering the value of course, but even the value is not so important at this point). The chosen pot will not be PCB mounted, but I don't think it is a big problem to solder 6 wires.
Quicksilverproac
« Reply #4 on: 7 Jun 2013, 03:20 pm »
Thanks Poty....I am not sure about the clearance from the center of the shaft to the pcb. It look like the front panal hole needs to be higher.
