Rigid Thinking
0 Members and 1 Guest are viewing this topic. Read 1936 times.
SteveFord
Rigid Thinking
« on: 21 May 2013, 11:04 pm »
Did you ever get something into your head that things just HAVE to be the way they are?
I put on some Doors in memory of Ray Manzarek and was walking around downstairs and it struck me that it sounded best from the kitchen instead of from the couch.
I grabbed the right hand speaker and gave it a good twist to the right,
grabbed the left hand speaker and gave it a tug to the left.
This is pretty much how I had the 3.7s and guess what?
After a quick walk around the place it sounds best from the listening spot.
I did a little additional screwing around with the angles since the pictures were taken, messed with the drapes some and all is well.
The moral to this bit is it's a mistake to get locked into thinking that something HAS to be done a certain way or else it won't work right.
I should remind myself of that once every so often!
« Last Edit: 22 May 2013, 09:42 am by SteveFord »
TitaniumTroy
Re: Rigid Thinking
« Reply #1 on: 22 May 2013, 01:24 am »
Been there too many times to even count  :duh:
josh358
Re: Rigid Thinking
« Reply #2 on: 23 May 2013, 09:46 pm »
I've found that the perfect speaker position is the one you had them in and somehow forgot to mark with tape.
Rclark
Re: Rigid Thinking
« Reply #3 on: 1 Jun 2013, 04:51 am »
Where mine are right now between my two large diffuser arrays it's like oh my god...
Every time I walk into my room I think, no, it can't really be that good, I'm imagining it, be objective self, be objective, it's the only way to improve, then I sit down and hit play.
 :o :o :o :o
... :o
Magnepan, all day long!
Emsquare
Re: Rigid Thinking
« Reply #4 on: 1 Jun 2013, 10:51 pm »
Truth
Rclark
Re: Rigid Thinking
« Reply #5 on: 3 Jun 2013, 11:28 pm »
always have tape. My floor was once crisscrossed with it when first getting accustomed.
