Thanks for the recommendation neekomax, but I'm not really a fan of horn loaded speakers. I've heard good things about these, but probably not for me, I'd have to hear them for an extended listening session before I dropped the $$.
In my opinion, for your first build I would consider designs where you can contact the designer in case you have questions. I would start with Vapor Audio, Selah Audio, and DIYSoundGroup. From there, consider what comes with the kit to determine what other expenses will be involved in the build. Things like binding posts, damping, wire, parts to construct the crossover, etc. will add more cost. Will you be building your own stands for a potential 2-way kit?
For the record, I think just about all the kits that he's mentioned and have been recommended so far have designers who are easily accessible and are very responsive. There are posts on the Statement series, etc. on other forums almost daily.
The SEOS are not traditional horn-loaded speakers. If you're thinking of the 'honkiness' and blare, these are very very different. Also The Tempest was also designed by Jeff Bagby who is *highly* respected (his kits at Meniscus are also worth looking at). I have built several of his designs and they are always smooth with an expansive coherent presentation. I doubt the Tempest would be any different.In describing the Tempest vs. his other designs Jeff more or less said;The speaker really surprised me and gave me one of the best sounding high efficiency (98 dB) speakers I have ever heard in my life. If I didn't have so many speakers already (and one set is a fairly high efficiency set of towers with Focal drivers and Scanspeak tweeter) I would seriously consider building a furniture grade set of cabinets and living with a pair of Tempests as my personal reference high efficiency speakers for many years to come. I still may. They way-out-performed my expectations, and I don't blubber over all of the speakers I design, because all of them have compromises, but these really sound great in my opinion.I am not a SEOS/diysoundgroup fanboy - far from it - but I would build anything Jeff designs in a sec, with no doubts. So even if you pass on the Tempest, check out what he has at Meniscus to see if any interest you.
Going to toot my own horn here, but there are also kit versions of the Vapor Breeze and Stiff Breeze available, featuring the RAAL 70-10D in time aligned baffles with 4 component, 2nd order acoustic crossovers.http://www.vaporsound.com/We'll be at the Newport Beach show later this month with the Nimbus.Stop by for a listen to what a Vapor system sounds like.
For a mere $630 all in (plus whatever finish), this would be cool to build. The SEOS waveguide is an open source collaborative design. Love what these guys are doing.http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-series-kits/fusion12-kit.html
